Download houdini 9.1 (for Ubuntu 7.10). Install it. Run. Press ‘install a non-commercial license’. Get error:
'Error installing key: LICENSE Generic Houdini-Master-NonCommercial ….
Unable to read/modify license file. …'
In License Administrator see:
*The license server is running.
*The license server may not serve licenses.
*The license server does not allow license modifications from this machine.
Also note that after installation I did not find sesinetd in the /etc/init.d and ran it from /home/ilya/hfs9.1.124/houdini/sbin
Suggestions?
Well.. and Where is this license file?
And diagnostic information:
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on: Wed Feb 6 13:55:38 2008
Local host name: ilya-desktop
Local server code: 93f43000
Local ip address: 127.0.1.1
Number of servers: 1
License server name: ilya-desktop (ilya-desktop)
License server server code: 93f43000
Server ip address: 127.0.1.1
License server is running: Yes
May read licenses from server: Yes
Has SERVER license: No
License server version: 9.1.124
May modify server from this machine: No (no license file permissions)
Redundant server keys: 0
Name Code Redundant Connected Transmission OK
License Administrator version: 9.1.124
Http proxy host: (none)
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] Yes
Installed licenses:
LicID Platform Product Ver Avail Expiry
sesictrl -i output:
—– SERVER ilya-desktop ——–
*** WARNING *** - No valid server lines found
hserver -l output:
Hostname: ilya-desktop
Uptime: 1:06:58
License Server: ilya-desktop
Server Version: sesinetd9.1.124
Version: Houdini9.1.124
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
7065 of 7996 Mb available
CPU Usage: 2% load
0 active tasks (4 slots)
Error installing key:... Unable to read/modify license file
25190 6 0- Buddha
- 12 posts
- stevenong
- 1631 posts
- Buddha
- 12 posts
- stevenong
- 1631 posts
- Joshua Behrens
- 2 posts
- Joshua Behrens
- 2 posts
- goldfarb
- 3455 posts
