Indie - Output Driver
   3308   6   1
After several months of waiting…..we finally are able to render using Redshift in the RenderView (previously only MPlay or straight to disk). To facilitate this…we have 2 ROP's (One for IPR and One for Rendering).
But…I'm getting an error when I try to IPR in RenderView:
Error: Output driver not supported in Houdini Indie.
I'm only aware of the Animation render size restriction and the full Scene Export restriction for Indie.
Can someone confirm if this (Output Driver) is an oversight or an intentional restriction?
Edited by TwinSnakes007 - July 9, 2016 13:37:43
Houdini Indie
Karma/Redshift 3D
41 views and no response.
Since I'm a paying customer (Indie), how do I get official support for my question?
Houdini Indie
Karma/Redshift 3D
ask on the redshift forum juanjo gonzalez if he confirms the problem he can make a RFE or both.
there is also a manual:
https://docs.google.com/document/d/1Tdh7MyeebbgVuy7Xktf01G2i1pAnShmXWnfGAnHeU4E/edit?usp=sharing [docs.google.com]
Daryl Dunlap
you always can make a RFE for bugs:
http://www.sidefx.com/Support/report-a-bugrfe/ [sidefx.com]
Hi
If you roll back to version v2.0.48 it will work fine with Indie.
-b
http://www.racecar.no [www.racecar.no]
Fixed with release 15.5.535
The circle is now complete…..one Renderer to rule then all!
Go Redshift!
Houdini Indie
Karma/Redshift 3D
Broken with release 15.5.565
Getting same error. Can any Houdini Redshift users confirm?
I assume I need to roll back my version of Redshift?
Edited by art3mis - Aug. 28, 2016 20:48:33
Working fine here with H 15.5.581 and RS 2.0.58
Houdini Indie
Karma/Redshift 3D
