Q: linking UI value parameters from subnet back to nodes/values inside?
   1326   2   0
I cannot seem to finds this on the forum, but reckon it is something very simple?
I have created a little subnet from a simple scatter/copy network, and ‘promoted’ some of the values into the subnet UI.
These ‘top sliders’ all work just fine.
What I also have is two stamp variable values which I would like to see in the subnet UI.
So I don't have to dive into the subnet again.
I can add these two UI values easily, but how can I link these back to the copy node value fields, so the copy/scatter network works again?
It's probably a simple ‘routing’ variable, but cannot see it atm.
cheers!
rob
p.s. This is probably the same for a HDA?
Apprentice Attribute / Houdini 17.0.381 / GTX 970 - driver 411.63
bump.
Is this not possible? Can this be done in a HDA?
Any links, tips etc. welcome!
rob
never mind, figured it out :-)
just some basic reference parameter copying and expressions.
