Hello guys,
I just followed this (incredible) tutorial by Tolya Shuverov to create a spider web (https://vimeo.com/163840170). [vimeo.com]
Now I wanted to export to Maya using Alembic, I used file node or the rop alembic node, but when I import it in Maya it results in a single transform node with thousands of shape nodes inside (one for each Houdini primitive). So I can't manipulate it, and even opening the attribute editor is a very long process.
How can I export the file so that in Maya I can see a transform node for each primitive ?
Thank you
Ray
Export alembic to Maya problem
2627 1 1- madrenderman
- 129 posts
- madrenderman
- 129 posts
