FAQ FAQ      Search Search      Memberlist Memberlist      Usergroups Usergroups      Register Register      Profile Profile      Check private messages Check private messages      Log in Log in
Can't figure out Voronoifracture create output group problem
Post new topic   Reply to topic    Houdini Forum Index -> Houdini Apprentice
View previous topic :: View next topic
Author Message
MPiland
Lurker
PostPosted: Wed Jun 06, 2012 11:39 pm GMT    Post subject: Can't figure out Voronoifracture create output group problem Reply with quote
So, I'm following the smashing columns tutorial and I'm at the part where I'm assigning materials. In the circle_object1 network, there's a node called "file" and it says to attach a material node to it. So I do. Then it says in that node paramters, to type "inside" in the group field. Well that seems to not work for my scene. When I click the down arrow next to the field, nothing comes up but in the video he has a long list of items. Is there something I'm missing? I've attached my HIP file. I'm using Houdini 12 BTW. Thanks!
Column.hipnc
 Description:
Download
 Filename:  Column.hipnc
 Filesize:  1.38 MB
 Downloaded:  182 Time(s)
Back to top
View user's profile Send private message
sadhu
Houdini Adept
PostPosted: Thu Jun 07, 2012 2:09 am GMT    Post subject: Reply with quote
Go to
/obj/AutoDopNetwork/rigidbodysolver1/voronoifracturesolver1/fracture_SOP_solver
go to groups para. and turn on creat output groups.
Now that material node will show you inside group.
Back to top
MPiland
Lurker
PostPosted: Thu Jun 07, 2012 7:40 am GMT    Post subject: Reply with quote
Ok thanks! Is this something that changed in Houdini 12 from 11? Or did they conveniently forget to put that in the tutorial?
Back to top
sadhu
Houdini Adept
PostPosted: Thu Jun 07, 2012 8:08 am GMT    Post subject: Reply with quote
When you fracture any geo in H11 using voronoi fracture tool, by default create output groups option is turned on. But in H12 , by default it is turned off so it doesn't create groups.
Back to top
MPiland
Lurker
PostPosted: Thu Jun 07, 2012 8:31 pm GMT    Post subject: Reply with quote
Ok when I go to that path, it's greyed out. Any ideas? I even tried loading it in Houdini 11, but that option is still greyed out...there must be something I'm missing. Please any help would be greatly appreciated! I really want to finish this tutorial Confused
Back to top
sadhu
Houdini Adept
PostPosted: Fri Jun 08, 2012 2:23 am GMT    Post subject: Reply with quote
select your rigidbodysolver node and Rclick on it and select allow editing of contents, do the same thing for voronoifracturesolver1, you will be eble to edit the contents inside.
Back to top
MPiland
Lurker
PostPosted: Fri Jun 08, 2012 6:20 am GMT    Post subject: Reply with quote
I feel dumb lol thank you!
Back to top
MPiland
Lurker
PostPosted: Mon Jun 11, 2012 8:53 pm GMT    Post subject: Reply with quote
Actually, looking at this again and trying again, this isn't an option in the "fracture_SOP_solver" node...at least not when highlighted. Is there anything else I'm missing? I'm uploading the HIP file again because I redid the tutorial just to make sure I'm not missing anything. I even went further to the "voronoifracture" node and and in the "Groups" param checked the "Create Output Groups" box. Do I need to re render the bgeo file?
EDIT: Ignore...figured it. I just needed to move the slider along...it was giving me a warning saying that there were no groups, but it's because it hadn't been shattered yet. Embarassed
Column_04.hipnc
 Description:
Download
 Filename:  Column_04.hipnc
 Filesize:  1.39 MB
 Downloaded:  203 Time(s)
Back to top
Display posts from previous:
Post new topic   Reply to topic    Houdini Forum Index -> Houdini Apprentice All times are GMT - 5 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
phpBB component v1.2.4 RC3 by Adam van Dongen. Based on phpBB © 2001, 2002 phpBB Group
