FAQ FAQ      Search Search      Memberlist Memberlist      Usergroups Usergroups      Register Register      Profile Profile      Check private messages Check private messages      Log in Log in
Point instance procedural
Goto page Previous  1, 2, 3  Next
Post new topic   Reply to topic    Houdini Forum Index -> Technical Discussion
View previous topic :: View next topic
Author Message
wywait
Lurker
PostPosted: Sun Jun 03, 2012 11:55 pm GMT    Post subject: Reply with quote
circusmonkey wrote:
Quote:
Hey guys, Is it possible to use single scatter sss with the point instance procedural? I could have sworn I had it working earlier but recently all I get is black renders.
Mike
Cannot say Ive looked into that. do you have a file ?
Rob
Sorry for the delay. Here's an example of what I'm talking about. Single scatter sss doesn't calculate from what I can tell with fast point instancing.
point_instance_procedural_v01.hipnc
 Description:
Download
 Filename:  point_instance_procedural_v01.hipnc
 Filesize:  930.03 KB
 Downloaded:  350 Time(s)
Back to top
View user's profile Send private message
Stalkerx777
Socialite
PostPosted: Tue Jun 19, 2012 5:19 am GMT    Post subject: Reply with quote
Hi guys! Could you tell me is it possible to use fast point instancing with delayed load procedural on instantiated object?
It works fine with full point instancing, but not with new point_instance_procedural.Is it limitation or bug?
Ok, i know i can load bgeos right in point_instance_procedural with instancefile attribute, but in this case i need to assign materials somehow ( which is nicely done with delayed load and separate material.ifd file).
Thanks.
_________________
Alexey Sadrutdinov
Back to top
circusmonkey
Houdini Guru
PostPosted: Tue Jun 19, 2012 3:36 pm GMT    Post subject: Reply with quote
The docs do not mention it as something that's supported. Did support say anything ?
Sorry wywait I just don't have the time right now to dig into your file. If it did work and now does not you should be contacting support.
Rob
_________________
Monkey Magic @ DD Vancouver
Back to top
View user's profile Send private message Send e-mail AIM Address
wywait
Lurker
PostPosted: Tue Jun 19, 2012 4:49 pm GMT    Post subject: Reply with quote
We've been in contact with support. It's a know bug. I believe they're looking into it.
Back to top
SYmek
Houdini Guru
PostPosted: Wed Jun 20, 2012 5:46 am GMT    Post subject: Reply with quote
Thanks.
I don't think that's possible, because these two are both procedurals, and Mantra can't stack procedural geometry shaders (which would be awesome btw).
Back to top
View user's profile Send private message AIM Address
halfdan
Houdini Adept
PostPosted: Wed Jun 20, 2012 2:50 pm GMT    Post subject: Re: SSS and point instance procedural Reply with quote
Don't think this ever worked. The problem is with how the SSS does the point cloud generation and the way Mantra's named scopes work. Scopes only work on top-level named objects, not named objects generated by procedurals.
We've introduced a new automatic scope, "scope:self", which can be used as an argument to the "scope" parameter of the VEX raytracing functions to restrict them to the currently shading object only.
This allows fast point instanced objects to work with both single- and multiple-scattering.
Will be in tomorrow's build (H12.0.663).
Back to top
View user's profile Send private message Visit poster's website
alejandro
Houdini Expert
PostPosted: Wed Jun 20, 2012 3:15 pm GMT    Post subject: Reply with quote
Shocked Niceeee!!!
_________________
http://www.linkedin.com/in/alejandroecheverry
http://vimeo.com/lordpazuzu/videos
Back to top
View user's profile Send private message Send e-mail MSN Messenger
circusmonkey
Houdini Guru
PostPosted: Wed Jun 20, 2012 5:29 pm GMT    Post subject: Reply with quote
Half dan , can we get a working example of this ? . On a side has anyone be able to get a looped geometry animation coupled with a random offset per instance to work ? when using a file sop.
Rob
_________________
Back to top
halfdan
Houdini Adept
PostPosted: Thu Jun 21, 2012 12:42 pm GMT    Post subject: Reply with quote
Attached is a scene that does both, except that instead of using the file sop, it uses the "instancefile" attribute to point to a bgeo at render time.
 Description:
 Filesize:  1.01 MB
 Viewed:  3005 Time(s)
sss_anim.hip
 Description:
Download
 Filename:  sss_anim.hip
 Filesize:  1.24 MB
 Downloaded:  415 Time(s)
Back to top
wywait
Lurker
PostPosted: Fri Jun 22, 2012 12:20 am GMT    Post subject: Reply with quote
That's awesome! Thanks guys. And it works with caustics. Score.
From what I can tell there's no extra setup either. Is that correct? Can you think of an example where one might want to pass custom arguments to the scope parameter?
Mike
Back to top
fsimerey
Houdini Adept
PostPosted: Fri Jun 22, 2012 2:41 am GMT    Post subject: Reply with quote
Just another exemple.
92 614 instanced points
46 different characters (5000 polys each)
46 different textures
 Description:
 Filesize:  682.63 KB
 Viewed:  2648 Time(s)
Back to top
circusmonkey
Houdini Guru
PostPosted: Fri Jun 22, 2012 7:27 pm GMT    Post subject: Reply with quote
Hi fsimerey,nice work any chance you can make the image smaller currently it fills my browser Smile . Feel free to show an example of how you did it or any hip files for others.
_________________
Back to top
vbk!!!
Houdini Adept
PostPosted: Mon Jul 02, 2012 1:58 am GMT    Post subject: Reply with quote
very nice work, fsimerey
I woud love to check an .hip file if possible : I am trying to make the same kind of stuff so ...
_________________
http://vimeo.com/vbkstudio
Back to top
View user's profile Send private message Send e-mail Visit poster's website
circusmonkey
Houdini Guru
PostPosted: Mon Jul 02, 2012 6:27 am GMT    Post subject: Reply with quote
instancefile >
I have created an instancefile attribute. the string reads $HIP/geometry/horse_v01.`padzero(4,$RANDOFFSET)`.bgeo . This is coupled with a looping attribute called RANDOFFSET . This way each frame in the sequences has a random start value and loops when I scrub the time line.
See image from details view. I scrub the time line and it works as expected. I render any frame below 80 which is when the loop resets and the objects render but with no offset per point in the animation. If I render over frame 80 which is past the original frame range and I get a blank render. Yet the attribute is correct and works.
This make me question just how does the instancefile work per point. Is it not able to read a sequence of bgeo files ? per frame with an offset. Even though as you can see from the image attached each point should get a different start frame and loop.
Rob
 Description:
 Filesize:  28.06 KB
 Viewed:  2681 Time(s)
_________________
Back to top
johm
Lurker
PostPosted: Mon Jul 02, 2012 9:15 am GMT    Post subject: Reply with quote
Not sure exactly how you're using the looping variable in conjunction with the already randomly offset looping index value inherent in the file name. Seems redundant to carry around the extra RANDOFFSET point attribute, unless you're using it somewhere else.
This works for me:
grid->scatter->attribcreate
AttribCreate:
Name = instancefile
String = $HIP/horse_dir/horse.`padzero(4, wrap($PT + $F, 1, 100))`.bgeo
Back to top
fsimerey
Houdini Adept
PostPosted: Mon Jul 02, 2012 12:09 pm GMT    Post subject: Reply with quote
Sorry for time to reply, i was very busy...
And i resized the picture !! Sorry for that.
My file is very simple given that all characters are at this time, without animation. It will be the next step...
I have 3 attributes:
- pscale (for adjust size of characters)
- numcast (between 1 to 45, to identify characters)
value exp: ceil(rand($PT+1232654) * 45)
- instancefile (to get the geometry based on numcast)
value exp: $HIP/geo/public_europe/rocket_casual_bat_`point("../attrib_numcast", $PT, "numcast", 0)`.bgeo
The only trick here is in foreach SOP by 'Each Attribute Value' to setup material with an override for 'BaseColorMap' based on numcast attribute to avoid oversize memory.
I can uplaod an hip file, but without characters geometry, it's not very helpful. But let me know.
P.S. vbk, si tu es sur Paris, on peut se rencontrer. Ca serait plus simple pour te passer des fichiers
 Description:
 Filesize:  23.5 KB
 Viewed:  2646 Time(s)
 Description:
 Filesize:  53.07 KB
Back to top
circusmonkey
Houdini Guru
PostPosted: Mon Jul 02, 2012 4:05 pm GMT    Post subject: Reply with quote
Hi John,
Ive since discovered a bit of bug with the instancefile , it only works with fast point instancing using full point instancing it fails.
At least we now have a looping animation with a random start frame thats instanced.
horseInstance_v01.mov
 Description:
Download
 Filename:  horseInstance_v01.mov
 Filesize:  700.26 KB
 Downloaded:  345 Time(s)
_________________
Back to top
vbk!!!
Houdini Adept
PostPosted: Tue Jul 03, 2012 2:48 am GMT    Post subject: Reply with quote
thx for your explanation fsimerey.
I'll try to follow your steps.
If I meet some issue I let you know.
Je suis sur Paris ( Saint Ouen pour être exact). Je serais ravi te de rencontrer à l'occaz.
_________________
Back to top
jeff
Houdini Guru
PostPosted: Tue Jul 03, 2012 10:01 am GMT    Post subject: Reply with quote
circusmonkey wrote:
Hi John,
The goal is to completely replace full point instancing with fast point instancing, because it goes to 11.
_________________
Back to top
Netvudu
Houdini Adept
PostPosted: Tue Jul 03, 2012 11:23 am GMT    Post subject: Reply with quote
Should I expect to get a huge decrease of memory management and performance while instancing with the Micropolygon renderer? Both PBR and Raytracing show great response, but as soon as I change to Micropolygon memory goes over the roof as well as render time. It affects fast point instancing, full, and delayed loading.
H12.0.655, Win64 here
_________________
Javier Meroño. Head of VFX Courses at FX Animation, Barcelona.
Back to top
circusmonkey
Houdini Guru
PostPosted: Tue Jul 03, 2012 4:33 pm GMT    Post subject: Reply with quote
Hey Javier, can you post up a scene file ? . Recent H builds have had some improvements to instancing.
Rob
_________________
Back to top
halfdan
Houdini Adept
PostPosted: Wed Jul 04, 2012 8:53 am GMT    Post subject: Reply with quote
Not a bug; it's completely by design. With full point instancing you can simply instantiate the file procedural multiple times and vary its arguments. This isn't possible with fast point instancing, and so the "instancefile" and "instanceblurfile" attributes were added, to do this automatically at render time.
However it's missing a way to specify a material archive right now. We're working on that.
Back to top
halfdan
Houdini Adept
PostPosted: Wed Jul 04, 2012 8:57 am GMT    Post subject: Reply with quote
This is a known issue with REYES algorithms, like micropoly. We have to generate geometry for all instances, unfortunately. We're looking into ways to reduce this. However, for now, it's recommended to do instancing only with raytracing (which is what PBR uses as well), which completely shares acceleration data and geometries across instances.
Back to top
Netvudu
Houdini Adept
PostPosted: Wed Jul 04, 2012 10:25 am GMT    Post subject: Reply with quote
ah, good to know...and good to know that you know Very Happy
_________________
Back to top
circusmonkey
Houdini Guru
PostPosted: Wed Jul 04, 2012 3:59 pm GMT    Post subject: Reply with quote
So that's basically multiple copies of the same object with various parameter changes. I used the instancefile approach to the horses because the help says that its used for reading bgeo files and in my case I have a sequence of Bgeo files so it seemed the right way to go. I'm sure you can understand the confusion my end.
I have done a search for instanceblurfile and the help returns nothing. Can you give some more details on this and how it should be used. Maybe also a breakdown on the approach to getting the correct motion blur on your instances.
Very useful information.
rob
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    Houdini Forum Index -> Technical Discussion All times are GMT - 5 Hours
Page 2 of 3
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
phpBB component v1.2.4 RC3 by Adam van Dongen. Based on phpBB © 2001, 2002 phpBB Group
