FAQ FAQ      Search Search      Memberlist Memberlist      Usergroups Usergroups      Register Register      Profile Profile      Check private messages Check private messages      Log in Log in
Shader view not working after upgrade to H11.
Post new topic   Reply to topic    Houdini Forum Index -> Houdini Apprentice
View previous topic :: View next topic
Author Message
clown
Talkative
PostPosted: Thu Aug 05, 2010 11:23 am GMT    Post subject: Shader view not working after upgrade to H11. Reply with quote
Problem is exactly as the title says: In Houdini 10, shader view works fine, however in Houdini 11 when I click on a shader ball that I want to view in shader view, the shader view shader ball just stays the default white, it doesn't even try to update it, it just does nothing.
Not sure if it makes a difference, but I do NOT have a workstation gfx card (I have an 8800gtx), but seeing as how it works in H10, I don't see that being the problem. Unless something was changed of course.
Information:
I tried these versions, didn't have success with either.
v11.0.446.9
v11.0.462
Windows Vista 64bit
Windows 7 64bit
Haven't tried Linux yet
Any help or ideas would be appreciated!
Back to top
View user's profile Send private message
jason_iversen
Houdini Guru
http://www.sidefx.com/com
PostPosted: Thu Aug 05, 2010 12:23 pm GMT    Post subject: Reply with quote
You're right; the shader view has taken a backseat to IPR rendering. If you havent tried IPR/Render View, please do -- it provides far more than the Shader View.
_________________
jason iversen, fx supervisor @ r+h, http://www.odforce.net
https://plus.google.com/103473736257525043693
Back to top
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
clown
Talkative
PostPosted: Thu Aug 05, 2010 12:26 pm GMT    Post subject: Reply with quote
oh, ok thanks!
Back to top
flyinmycoffee
Lurker
PostPosted: Thu Aug 12, 2010 8:56 am GMT    Post subject: Reply with quote
Actually the shader view just doesn't work. It can even make houdini freeze. I am sure that the issue will be resolved in future builds as a shader view is always useful.
Back to top
mzigaib
Houdini Expert
PostPosted: Thu Aug 12, 2010 5:42 pm GMT    Post subject: Reply with quote
In the build 469 shader view still not working with material shader builder.
It appears black.
Back to top
View user's profile Send private message Visit poster's website MSN Messenger
mzigaib
Houdini Expert
PostPosted: Thu Aug 12, 2010 9:15 pm GMT    Post subject: Reply with quote
Anyone else is getting this problem?
Back to top
mzigaib
Houdini Expert
PostPosted: Fri Aug 13, 2010 8:45 am GMT    Post subject: Reply with quote
Same problem with build 470.
This is really not working right, at least for me, all the shader goes black, if I delete some VEX nodes inside sometimes it appears right on the shader view but for most of the time the result is the same.
I also notice that if I try to see the decal shader from the gallery on the shader view Houdini freezes trying to calculate the result.
Would be just me having this kind of problem?
Back to top
JColdrick
Houdini Guru
PostPosted: Fri Aug 13, 2010 10:10 am GMT    Post subject: Reply with quote
Nope, not just you. As mentioned by Jason earlier, the shader view obviously hasn't had much attention and there's been major changes to shading. Try using IPR, it's far, far more revealing than the shader ball.
J.C.
Back to top
clown
Talkative
PostPosted: Fri Aug 13, 2010 1:18 pm GMT    Post subject: Reply with quote
Yeah after getting my question answered, I have found render view to be much better, much higher quality, and much more customizable since you have access to all of mantras settings, and you can add whatever else you want into the scene to help view reflections and refractions or whatever else
The only thing I miss from shader view is being able to rotate the shaded ball.
Listen to these guys and check out IPR render view.
If the reason you like shader view is because of the speed of it, you can easily just reduce mantras quality settings and IPR will go quite fast.
If however you like to be able to rotate the shaded object without having to rerender like you could in shader view, Im pretty sure you are out of luck on that one. Unless someone smarter than me knows some neat trick, but I doubt it
Back to top
ikerr
Houdini Adept
PostPosted: Fri Aug 13, 2010 2:22 pm GMT    Post subject: Reply with quote
If you'd like to tumble using IPR you can do the following:
1) Create a floating Render Viewer or split your viewport in half and make one of the halves a Render Viewer and the other a Scene Viewer.
2) Select a Scene View camera in the Render Viewer's camera menu. This will keep the two camera's in sync.
3) Start a render in the Render Viewer.
4) Rotate your sphere in the Scene Viewer and watch IPR update simultaneously in the Render Viewer. If your scene is quite simple, try lowering the Update Time and Delay Time in the Render Viewer for a more interactive experience.
--Ian
 Description:
 Filesize:  124.39 KB
 Viewed:  3426 Time(s)
Back to top
clown
Talkative
PostPosted: Fri Aug 13, 2010 2:40 pm GMT    Post subject: Reply with quote
Yeah that's pretty much what I have been doing. Its not quite as interactive as the shader view was, but its very close, as long as the render doesn't take too long to update anyways.
Back to top
mzigaib
Houdini Expert
PostPosted: Sat Aug 14, 2010 3:08 pm GMT    Post subject: Reply with quote
Thanks for the feedback guys
I am glad to know(or not) that it's not just me.
I'll try to adapt myself to not use it.
Back to top
JColdrick
Houdini Guru
PostPosted: Mon Aug 16, 2010 9:53 am GMT    Post subject: Reply with quote
The cool thing is that IPR isn't really intended to be a shader ball replacement - it's giving you feedback with more relevant data typically in a lighting environment closer to what the final will be like i.e. invaluable. Of course, sometimes it's handy to have a standard sphere/torus/teapot when doing very preliminary setup, I often have a Sphere SOP or obj in a hip for just that reason. It's not *quite* as fast as the shader ball, but it's not much slower and obviously far more useful for catching things like how shadows/highlights will fall, etc.
J.C.
Back to top
AndyAl92
Lurker
PostPosted: Fri Feb 17, 2012 8:52 pm GMT    Post subject: Reply with quote
I do not understand the other method (ipr).
Is it like this?
You have to hide all other objects, create light, create sphere, apply uvs, and rendering in the same scene your working on?
Houdini 11 was the first Houdini I used. Laughing
Will Shader View be working in Houdini 12?
Back to top
Display posts from previous:
Post new topic   Reply to topic    Houdini Forum Index -> Houdini Apprentice All times are GMT - 5 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
phpBB component v1.2.4 RC3 by Adam van Dongen. Based on phpBB © 2001, 2002 phpBB Group
