FAQ FAQ      Search Search      Memberlist Memberlist      Usergroups Usergroups      Register Register      Profile Profile      Check private messages Check private messages      Log in Log in
need polysplit by curve
Post new topic   Reply to topic    Houdini Forum Index -> Technical Discussion
View previous topic :: View next topic
Author Message
luoqiulin
Houdini Adept
PostPosted: Wed Apr 11, 2012 9:30 am GMT    Post subject: need polysplit by curve Reply with quote
there's a curve on the geometry, i need the curve split this geometry.
i only found the "polysplit" looks usefull, but it must split mulally.
any good idears?
and if use the polysplit sop,i need find out every prims' uv nearst to the curve's points, don't know how to find out it yet.
 Description:
 Filesize:  249.94 KB
 Viewed:  1145 Time(s)
_________________
http://vimeo.com/user3971456/videos
Back to top
View user's profile Send private message
tjeeds
Houdini Adept
PostPosted: Wed Apr 11, 2012 11:12 am GMT    Post subject: Reply with quote
This gentleman has come up with what you're after, you might want to ask him some questions.
http://forums.odforce.net/index.php?/topic/15184-poly-curve-split/
_________________
Jesse Erickson
Fx Animator
WDAS
Back to top
View user's profile Send private message AIM Address
luoqiulin
Houdini Adept
PostPosted: Thu Apr 12, 2012 9:08 am GMT    Post subject: Reply with quote
thank you Laughing i think his cook way is better
_________________
Back to top
Simon
Houdini Guru
PostPosted: Thu Apr 12, 2012 3:28 pm GMT    Post subject: Reply with quote
You can do that sort of thing with a cookie sop, you just need to turn line into a ribbon first.
Back to top
View user's profile Send private message Send e-mail Visit poster's website
grayOlorin
Houdini Expert
PostPosted: Thu Apr 12, 2012 7:54 pm GMT    Post subject: Reply with quote
I think the issue with the cookie SOP is that it can be a bit unpredictable at times. This seems like a sensible alternative
_________________
-G
Back to top
Simon
Houdini Guru
PostPosted: Fri Apr 13, 2012 2:21 am GMT    Post subject: Reply with quote
if you look carefully when he separates all the pieces this has too. I think he must have used the cookie sop inside his otl as driving the polysplit sop from a curve isn't possible, unless it has drastically been changed in H12, I've not had time to check.
It would be brilliant if we can now drive the polysplit sop itself from a curve. I wrote an hdk sop to do that many moons ago because of exactly that limitation. If that has change that would be amazing. Never understood why 95% of sops are procedural but a handful are not.
Back to top
jeff
Houdini Guru
PostPosted: Fri Apr 13, 2012 10:14 am GMT    Post subject: Reply with quote
The Polysplit has changed dramatically.
The PolySplit SOP now allows you to create intermediate points on polygon faces and you no longer are restricted from placing intermediate points on polygon edges but anywhere on the polygon face. This allows you to define a few edge points on or off edges and generate a new split edge that will cut all intermediate polygon edges respecting the drawn split curve shape.
I believe there is a new asset using the added nomenclature in the Polysplit field taking advantage of this new feature.
_________________
Back to top
grayOlorin
Houdini Expert
PostPosted: Fri Apr 13, 2012 8:23 pm GMT    Post subject: Reply with quote
Jeff, by this statement do you mean that there is a new digital asset in Houdini that does kinda of what we see in the video post above? This is something that would be pretty useful to have in MANY cases
_________________
-G
Back to top
Display posts from previous:
Post new topic   Reply to topic    Houdini Forum Index -> Technical Discussion All times are GMT - 5 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
phpBB component v1.2.4 RC3 by Adam van Dongen. Based on phpBB © 2001, 2002 phpBB Group
