Crash logs
Locating crash logs:
Windows
The crash error pop-up should tell you where the crash log has been written to. Most often it will be in your home directory under AppData. Ensure you select "Hidden Items" under the View menu in your file browser.
For example:
C:/Users/username/AppData/Local/Temp/houdini_temp
Mac OSX
On OSX crash logs are saved in /tmp. You can only see this directory through a Terminal (Utilities->Terminal), not through the interface.
Linux
On Linux, the crash logs are saved in /tmp/houdini_temp
