driving scale with point distance
   6650   5   2
Hi all
I'm trying to drive the scale of copied boxes by the proximity of a circle. I've been at it for a few days and its driving me nuts.
I have gotten as far as having the translation of the inner circle to drive all of the boxes' scale in x & z, but I want the scale to be driven mutually exclusively by the circles proximity to each of them,
Here is an attached file with where i'm going wrong
any help?
Landin
circles closer.hipnc (67.7 KB)
You can use the distance() expression to figure out the distance between two points. In the copy node I added a new variable called prox and added the following expression below. The expression calculates the distance between the centerpoint of the small circle to the corresponding point.
You were close.
distance(
centroid(“../xform2”, D_X),
centroid(“../xform2”, D_Y),
centroid(“../xform2”, D_Z),
point(“../point1”, $PT, “P”, 0),
point(“../point1”, $PT, “P”, 1),
point(“../point1”, $PT, “P”, 2)
circles_closer_484_v2.hipnc (80.7 KB)
Available for new projects
I just wanted to say thank you for helping me. Here is what I ended up doing with the file.
Landin
circles_closer_484_v2_104.hipnc (114.8 KB)
Your example reminds me of the pong game.
You can see the endless possibilities here right. You can copy objects to a point cloud and let that object react on an object flying trough that point cloud.
Well glad I could help.
Cheers Landin
Aye, it does remind me of pong, now that you mention it. It was to demonstrate a control solution for a touch pad screen.
I am very new to houdini. I have been learning as much as I can over the past 2.5 months. How long have you been using it?
I use it on/off for 3 years now and keep learning new things everyday.
I really like working in Houdini, it's so flexible, but here in Belgium it's hell to find a job as a Houdini artist. Pity!
Good luck with the touch pad project.
