In my fluid SOP I have the abbility to render out the fluid particles and/or fluid surface as bgeo.
I also have a RBD object in my Simulation. So if I render out a sim file from the autodopnetwork I have no access to it in my fluid sop to export out the particles or the surface of the pluid.
So do I have to run the simulation twice? for the export of the particles/surface of fluid and the rbd object?
Workflow FLIP/RIGID Body Export to File
5206 4 1- roughsporty
- 191 posts
- johner
- 809 posts
You can use a network of Fetch ROP nodes in /out to do this. Create a FileCache node to save out your RBD sim, then point one Fetch ROP at its internal “rop_geometry1” node. Then use another Fetch to point at the import_fluid's “render” node.
Plug both of these ROPs into a Merge ROP, then just Render from the Merge. The default order is Frame by Frame, so for each frame the RBD will write out, then the fluid.
You could just use merged Geometry ROPs instead of Fetch-ing if you like, but I personally prefer the workflow of having FileCache and DOP I/O inside my network.
- roughsporty
- 191 posts
- johner
- 809 posts
- roughsporty
- 191 posts
