print out random variables and expression evaluation time
   2965   2   2
hello, i want to input random values to some parameters for a shader and see what kinds of images those random parameters would produce i want to keep a record of what random values were used also so i could use the same values in the future.
i am using hscript + shell scripting. i was trying two ways of doing this.
1) use a random expression for the shader variable. i.e. rand(system(date))
i was using the example hscript+unix shell scripts.
#! /bin/csh -f
#check to see if user suppled the correct number of arguments
#- exit if not
if ($#argv < 4) then
echo “USEAGE: ren_script <hip_file> <out_file> <start> <end>”
exit
endif
# set up user supplied arguments
set HIP_FILE = $1
set OUT_FILE = $2
set START = $3
set END = $4
set TEST
for i = $START to $END
echo ‘ch(“/obj/geo1/tx”)’
end
ENDCAT
the problem for this particular situation is:
-echo just prints out ‘ch(“/obj/geo1/tx”)’ instead of the actual value. in the textport window, this command works and prints out 0
-im not sure when the expression is evaluated. is the expression evaluated only when it is currently being rendered. unfortunately since echo was not working, i could not extract the value of the variable. would i have to “cook” the shader first in order to find out what the random variable would be?
2) feed the *.hip file a random number i generated in the unix shell. i.e. using gawk srand() and rand() functions.
i am havint all sorts of problems with this, i think this may be working:
set randomnumber = system( “unix gawk ‘BEGIN { srand();print rand() }’”)
problem is, i have this for loop
#! /bin/csh -f
#- exit if not
exit
endif
set HIP_FILE = $1
set OUT_FILE = $2
set START = $3
set END = $4
set TEST = 22
set TEST = 44
echo $TEST
end
ENDCAT
this doesnt set TEST for some reason and just prints out 22 when it should be 44, so i am not able to set the shader variable.
I haven't tested this but try escaping the single quotes with a \
so
becomes
echo \'ch(“/obj/geo1/tx”)\'
Also in your second example it might be worth using setenv or set -g instead of just set. This will make the variables global and might do the trick.
To have an expression (like ch() ) evaluate, you need to put it in backticks – `, not ‘.
Also, ch() will just tell you what it is, it won’t set it. For that, you'll need the ‘opparm’ command.
– Antoine
Antoine Durr
Floq FX
antoine@floqfx.com
_________________
