Pre-flight checks out. AWC says all is good their side but the instance never launches after I submit. Just checking to see if anyone else is having this problem? Or if I need to buy a Mantra token although I think Indie supports one Hqueue job.
Thanks, Kevin
Hqueue in Indie hangs at instance launch
4841 10 1- kevinthebright
- 208 posts
- jrockstad
- 11 posts
I've been having some issues with cloud rendering via Indie as well. This is a copy / paste from a thread I made on the OD Force forums:
Any similarities to your troubles, Kevin?
My first thought was also that it could be an issue with the version of Houdini on the cloud machines not being able to process files from Indie, so hopefully someone can shed some light on that for us.
I've sent a couple jobs out but seem to have hit another snag. After I hit render I get the normal preflight / password dialogs, my browser opens to the Cloud Submit page, but after a while I get a dialog box with the message “The Houdini Cloud Submit daemon has terminated prematurely.” There is a direction to a log file - this seems to be the most relevant passage:
ERROR: AuthFailure: Unable to launch image ami-73607f1a as the product code 5D6864EE is not supported for the specified region, instance type and operating system combination. Please contact the vendor for more information.
- kevinthebright
- 208 posts
Hi John,
It might be. Houdini's EC2 browser page warning was looking for the Houdini version. Then in Jobs, the last dialogue before it stalls out is that it has initialized 13.359 (the last production build before .509 I think) but I'm running Indie .509 so it may be a versioning problem.
I submitted a support ticket which they been jumping on like a trampoline. Last iteration they asked me for my cloudsubmit.log which (on a Mac) is both hidden from view and buried. If you sudo find, etc in your terminal, you can find it no problem though. I sent mine in today and will let you know what they tell me.
Kevin
Kevin
- jrockstad
- 11 posts
- kevinthebright
- 208 posts
Support just replied
“Our developers agree that this could be a versioning issue. We will update the cloud version this week.
For future reference, if a job fails on the cloud, you can find out why by clicking on the View HQueue Jobs link on the cloud web page. Then keep clicking/diving into the failed Child Jobs until you reach the lowest job. The Command Output text area should show the error that caused the failure. You can also download the output.”
Kevin
Kevin
- jrockstad
- 11 posts
- TRex92
- 35 posts
- kevinthebright
- 208 posts
- jrockstad
- 11 posts
TRex92
I'm having a similar issue I can only seem to launch a single machine type through amazon which is the 20 ec2 Compute units with 7 gb's of ram. I hope they fix this soon. I should note I'm using a fully licensed version, but am still having a similar issue.
This seems to have done the trick… kind of. If I select that machine type my jobs will go through, only to fail with the same message that Kevin has been getting this whole time. TRex, are you able to get finished jobs from that machine or are yours also failing?
Kevin, the Compute Units thing is a little confusing. Basically it's Amazon's metric for the processing power in a single machine, so you can pick a machine with however many Compute Units but it's still only a single instance unless you specify that you want more in the HQueue Render properties.
- kevinthebright
- 208 posts
- kevinthebright
- 208 posts
