Hello my friends
I know we can fracture any object with Voronoi Fracture SOP or use Make Breakable option in the Dynamic network.
both method take me same fracture style that useful only for rocks , walls or similar.
What about another styles such as Wood fracturing , Glass or etc ?
for example about wood we should have some long an thin pieces with sharp edges .
Is there another method to achive another styles ?
I think that's because Houdini only use Voronoi algorithm , right ?
Different styls of fractures
5921 7 3- Jack.N
- 72 posts
- Sadjad Rabiee
- 1391 posts
- buki
- 1769 posts
try this
- Sadjad Rabiee
- 1391 posts
- Jack.N
- 72 posts
Yes , That's work perfectly , thanks.
But I think it can work only for some special projects.
What about if I wanna do it in the RBD Dynamics ?
Maybe I should change Fracture DOP network manually !?
I wanna create something like RayFire Wood destruction in the Max ,it can make very perfect wood destruction with perfectly details , Please check this videos :
https://vimeo.com/70413425 [vimeo.com]
https://vimeo.com/62777404 [vimeo.com]
Maybe Houdini need to add another fracture node with different algorithm (Voronoi for Rocks and another for woods) :!:
- -heavy-
- 62 posts
Hey Jack =]
this is the Wood Setup i use most of the time and it gives nearly the same
result like your rayfire examples.
the shattering is based on the normal voronoi fracture scale down scale
back Thing - if you have a lot objects pointing in different directions it can
be a bottleneck, but i think most of the time Wood is horizontal or vertical
scalable
the key then is the ConeTwist constraint, it has an angle value, that can
be used to delete constraint during the Simulation. so the Wood is first a
bit bend and then breaks apart.
if you have any questions feel free to ask.
cheerz
de Heavy
scalable
cheerz
de Heavy
Janko Kissel
Maya & Houdini Smoke and Demolition VFX-Artist
http://vimeo.com/heavyatvimeo [vimeo.com]
https://www.youtube.com/user/masterheavyone/videos [youtube.com]
- Jack.N
- 72 posts
-heavy-
Hey Jack =]
scalable
cheerz
de Heavy
That's really perfect , Thanks Heavy
- cedric kode
Jack.N-heavy-
Hey Jack =]
scalable
cheerz
de Heavy
Thanks very much Heavy for that help ! very simple and efficient ! Well Done Mate
