Hi
I wanna render my files out of the Houdini with cmd, Of course I can render it with hbatch.exe correctly.
But my problem is relative paths for File SOP , or others.
I take error for each File SOP that using $HIP for it's path .
for example I used this path in the file1 :
$HIPtest.bgeo
But I take this error :
Error saving geometry for: /obj/sphere_object1/file1
Command Exit Code: 1
How can I define $HIP (global variable) in the hbatch command ?
Define $HIP for hbatch.exe rendering
9607 15 3- Jack.N
- 72 posts
- PradeepBarua
- 443 posts
- Jack.N
- 72 posts
Sorry , but it doesn't work for me.
In the attached project I take two error when using hbatch.exe.
one error for geometry file , because I used $HIP/Geo/TestGeo.bgeo.
another error for Mantra node , because I used $HIP/Render/Test.$F.jpg for output.
Maybe that's because I didn't use hbatch.exe directly , I put these codes in the batch file , then I execute it :? If yes , so how can I solve it ?
echo render -V -I -C -f 1 100 mantra1 | “C:\Program Files\Side Effects Software\Houdini 13.0.401\bin\hbatch.exe” “C:\Users\Jack\Desktop\testHbatch\testHBatch.hip”
But this project rendered correctly if I use full path for File SOP and Mantra !!!
- PradeepBarua
- 443 posts
- Jack.N
- 72 posts
- PradeepBarua
- 443 posts
- Jack.N
- 72 posts
- luoqiulin
- 303 posts
Hi
I always do that on windows, no problems if it can be rendered in houdini.
Maybe you load your hip while you open hcommand,then the $hip path is the hcmd.exe path.
I use mread command
Open your command line tool
hscript
mread //path/to/file.hip
render -V /out/mantra
Or cd to your hip path first.or put your batch file in your hip path.
I use mread command
hscript
- Jack.N
- 72 posts
luoqiulin
Hi
I use mread command
hscript
I should test it , I think this is my answer , really thanks :wink:
- Sadjad Rabiee
- 1391 posts
- sl0throp
- 258 posts
In my experience $HIP fails in hbatch when:
1. $HIP refers to a mapped network drive, I usually substitute the full path. (See next suggestion).
2. $HIP is defined incorrectly - Open up the Alias and Variables check and see how $HIP is defined. I usually replace a mapped drive path with
//myserver/my_houdini_project
Also the use of $JOB is very helpfull.
- Jack.N
- 72 posts
sl0throp
Thanks for your reply , But unfortunately I didn't use mapped network , all of the files are local , Also $HIP defined correctly in the Alias and Global variables window !
- Jack.N
- 72 posts
- Sadjad Rabiee
- 1391 posts
- teresuac
- 5 posts
- futurelight
teresuac
$HIP refers to my drive letter in hscript. I just fix it in in changing my path with “/” instead of “\”.
For example :
c:\PROJECT\A\A.hip in cPROJECT/A/A.hip
Oh my gosh, thank you so much! After hours of confusion and trying, this fixed my batch render problem. All I needed to do was call my file path with forward slashes, and all my file textures loaded! To be clear for others in the future, all I had to do was change my python command from:
hou.hipFile.load(“C:\path\to\file\file.hip”)
to
hou.hipFile.load(“Cpath/to/file/file.hip”)
