What is the correct way to detect a user pressing the escape key during the execution of a python script.
In particular I am want to something like:
interrupted = 0
try:
hou.hscript('viewwrite -f 1 100 <view name> cfoo.\$F.jpg')
except:
interrupted = 1
In this case I can interrupt the viewwrite hscript command (and it kills the viewwrite as expected), however it does not seem to be caught by the try: statement..
What is the correct way to do this?
Correct way to detect ESC pressed in houdini python?
5070 6 1- cruiserandmax
- 34 posts
- Anonymous
- 678 posts
- cruiserandmax
- 34 posts
Have you ever used that class? I could really use an example for my case. I couldn't figure out how to get it to work. I tried the following and if I use ESC to abort the viewwrite part way through, or just let it complete normally without interrupting, the following code always returns True for aborted:
def doit():
aborted = False
with hou.InterruptableOperation(“doing stuff”, open_interrupt_dialog=True) as operation:
ret = hou.hscript(“viewwrite -f 1 40 Build_gg.panetab1.world.persp1 ctest/foo.\$F.jpg”)
operation.updateProgress()
if hou.OperationInterrupted:
aborted = True
if aborted == True:
print “aborted!”
else:
print “continuing on…”
def doit():
aborted = False
aborted = True
if aborted == True:
print “aborted!”
else:
- Anonymous
- 678 posts
cruiserandmax
Read about catching exceptions in Python. https://docs.python.org/2/tutorial/errors.html [docs.python.org]
- cruiserandmax
- 34 posts
Thanks again for trying to help. I combed over the python docs for handling exceptions as well as the houdini docs for hou.InterruptableOperation again.
From my understanding this should work:
def doit():
aborted = False
try:
except hou.OperationInterrupted:
aborted = True
if aborted == True:
print “aborted!”
else:
However when I run that function and hit Escape in the middle of the flipbook, I sometimes get “continuing on…” and sometimes get “aborted!”. If I run the function and let the flipbook complete on it's own I get “continuing on…” every time. So unless something is wrong with my code- it seems that either the hou.InterruptableOperation class is bugged, or there is something weird about how the interrupting of the hscript function is handled through the python hou.hscript() call.
I keep going over and over the details but I just can't figure out what I may be doing wrong. :cry:
def doit():
aborted = False
try:
aborted = True
if aborted == True:
print “aborted!”
else:
- cruiserandmax
- 34 posts
- graham
- 1904 posts
I'm surprised it worked in previous versions. hou.hscript() definitely is useful but whenever I consider using it I definitely expect nothing from it in terms of useful return information, error handling and interruptibility. It is still quite sad there is no HOM equivalent to viewwrite. It's only been RFE'd for forever.
