Deleted points in CHOP revert to their initial value
3642 10 2- Anti-Distinctlyminty
- 271 posts
Hi all,
I have some motion data that I'm trying to smooth out by using a filter in a CHOP network. Generally this seems to work ok, except that many of the points on the geometry will be deleted at some point in the animation, yet their channel data continues - and not a continuation of the last value that channel had before it was deleted (if anything, it looks like it reverts to the start value for some reason).
So, how do I get the channel to just hold the value it had when it was deleted?
Currently, using a trim is the only way to get it to hold the correct value, but I don't know how to do this procedurally, but I'm convinced that I'm missing something really obvious here.
- 271 posts
- 271 posts
- malexander
- 5156 posts
All channels within the same CHOP need to be the same length, so you can't trim some channels and not others (ie, if particles die at different times). Perhaps you can also import an attribute that indicates if the particle is alive or not, and then zero out the channel data when it's dead.
Still, it seems odd that the geometry CHOP wouldn't just hold the last value, or zero it. Using the first sample seems like an odd choice.
- 271 posts
twod
This is exactly why I feel like I'm going crazy here (and thank you for replying) - I don't know why this behaviour is the default or why there seems to be no way to change it.
I would do something like that, but doesn't that also suffers from the same issue? When the point is deleted, any attributes it carries are also screwed.
- 271 posts
Another thing I noticed, is that they revert to their start value after death when you have Organize by Attribute checked on. Without this on they seem to go to zero (or some other equally useless value.
So…is this considered a bug? In any case, how would people go about getting a channel to maintain it's value after it's deleted?
- andrewlowell
- 537 posts
- 271 posts
Thank you Andrew! That works splendidly. Unfortunately I don't understand the expressions, mainly because I've not yet gotten to grips with CHOPs themselves.
I really need to do a course (or something) in CHOPs. They seem so powerful, but resources out there are slim.
Also, I did actually log this as a bug as I think the default behavior is very unintuitive.
- 271 posts
- 271 posts
- YanivG
- 6 posts
I've recently ran into what I think is the same issue as you've described. I've made a small chops HDA to try to deal with it. Haven't tested it thoroughly beyond what I needed for my project but if it is of any use to you, feel free to check it out. Any questions/problems/improvements are most welcome.
/Yaniv
/Yaniv
Edited by YanivG - July 15, 2017 03:14:41
