While environments are slightly different for the existing systems, patience is required.
For Windows 10, Houdini 15.5 (I use indie), and Renderman 20.9:
Make sure Houdini is closed.
Using a text editor of your choice: I use Notepad++:
Open: C:\Users\(name)\Documents\(Houdini directory)\houdini.env
Where:
(name) = Windows Login Name (Check your User directory)
(Houdini directory) = Folder where Houdini preferences are saved, (Check your User\Documents directory)
Example: C:\Users\Rob\Documents\Houdini15.5\houdini.env
Add the following lines (note the direction of the slashes)
RMANTREE="(Drive)/Program Files/Pixar/RenderManProServer-(Version Number)“
PATH=”$PATH;$RMANTREE/bin"
HOUDINI_DEFAULT_RIB_RENDERER=prman(Version Number)
Where:
(drive) = C:
(Version Number) = installed Version, in my case 20.9
EXAMPLE: For those who may copy these, lines there is an extra space between C: and / for display purposes to prevent in the first line - REMOVE THE SPACE
RMANTREE=“C: /Program Files/Pixar/RenderManProServer-20.9”
PATH=“$PATH;$RMANTREE/bin”
HOUDINI_DEFAULT_RIB_RENDERER=prman20.9
Save the file.
Close the text editor.
Restart Houdini (or in my case Hindie.exe)
I was able to run the test file provided by tinyhawkus and the new renderman tutorial from Pluralsight.
THESE ARE NOT ALL THE STEPS REQUIRED. REFER TO HOUDINI HELP FILE FOR 15.5:
You will need OUT: Renderman RIS & SHOP Network, SHOP: Renderman Material Shop. Addtitional: Pixar materials, Pixar Lights.
RenderMan won't work...aargh!
39621 38 8- Rob Dahl23
- peasantmagic
I rage-quit on this a few nights ago (Mac OS X, Houdini Indie 15.5, RenderMan 20.9 Non-Commercial), but Rob Dahl23's guide for Win 10 above helped resolved it for me.
For Mac OS X, the houdini.env file is located in:
~/Library/Preferences/houdini/15.5/houdini.env
Open this in your favourite text editor, and add these lines to it:
RMANTREE=“/Applications/Pixar/RenderManProServer-20.9”
PATH=“$PATH;RMANTREE/bin”
- lewis_T
- 234 posts
- Dwaine Best
- 16 posts
- Dwaine Best
- 16 posts
- bonsak
- 459 posts
- Dwaine Best
- 16 posts
- bonsak
- 459 posts
Hard to say what's wrong with your setup but make sure that what is entered in your houdini.env file is actual paths that exists on your harddrive. I just installed 20.9 on OSX and this is what i have in my houdini.env file.
-b
RMANTREE="/Applications/Pixar/RenderManProServer-20.9"
PATH=$RMANTREE/bin:$PATH
-b
Edited by bonsak - June 1, 2016 12:27:57
- Dwaine Best
- 16 posts
- lewis_T
- 234 posts
- Dwaine Best
- 16 posts
- Druidl
- 4 posts
- varomix
- 460 posts
tinyhawkus
Dudes,
It works fine.
Add these lines to your houdini.env file.
RMANTREE=“cProgram Files/Pixar/RenderManProServer-20.9”
PATH=$PATH;$RMANTREE/bin
And make sure you have renderman ticked in the render prefs.
Here's a link to the scene, with everything required to render
rendermanHoudini [dropbox.com]
Hey Man
could you please share that scene again, the dropbox link expired
thank you
varomix - Founder | Educator @ Mix Training
Technical Artist @ Meta Reality Labs
- pluneau
- 10 posts
- varomix
- 460 posts
pluneau
I can not do the rendering on Windows 7 x64 with Renderman RIS21.1 and 15.5 Houdini! it appears in the render window “Generating scene” and it does nothing
are there any errors on the RIS node?
middle click on it if it's red, make a screenshot if possible
- Sankeerth Gs2
- syn2
- 5 posts
- anon_user_37409885
- 4189 posts
syn2
Anything that comes out from Pixar or Disney is convoluted as hell…just look at xgen.
Arnold took 15sec to install, hows that for comparison?
Pixar were asking on their Renderman forums for feedback to make their product more user friendly, if you're keen, but you have to get through the convulted forum log-in to get there
- zdmit
- 46 posts
For Houdini 19.0 and above. For anyone who will encounter similar issues.
1. Make sure RenderMan for Houdini is Python 3 version.
2. Use installation via packages (json file). RenderMan has provided a json file at: "C:\Program Files\Pixar\RenderManForHoudini-25.2\packages\renderman_for_houdini.json"
3. Copy-paste this file to: "C:\Users\Dmitriy\Documents\houdini19.5\packages" (houdini<your_version_of_houdini>).
4. Delete everything related to Renderman from houdini.env (if written before) as json file will do the same and if both are used together, it may cause conflicts. Related post: https://www.sidefx.com/forum/topic/71405/?page=1#post-302661 [www.sidefx.com]
Find "Package installation": https://rmanwiki.pixar.com/display/RFH25/Installation+of+RenderMan+for+Houdini [rmanwiki.pixar.com]
For Houdini 19.0 and beyond, RenderMan for Houdini can be installed with a packages file, found in the RfH installation directory.
3D Animation/Generalist.
