Pyro simulation (Fuel on path)
2849 3 1- unitmotion
- 15 posts
- Enivob
- 2519 posts
If you visualize your fuel you will see that is not burning quickly enough. As long as the fuel exists combustion will occur. Try to find a way to either emit less fuel or burn it more quickly.
Or:
Change the Source Volume from Add to Copy then loosen up the drag on the particles..
Or:
Edited by Enivob - Jan. 16, 2017 22:01:40
Using Houdini Indie 20.0
Ubuntu 64GB Ryzen 16 core.
nVidia 3050RTX 8BG RAM.
- unitmotion
- 15 posts
Enivob
It worked
Why is this happening
switch setting source smoke to fuel and i have more fuel
and I have to change the settings source volume to copy,
Why by default is add?
Edited by unitmotion - Jan. 17, 2017 06:26:33
- mdharper
- 3 posts
