Is Houdini suitable for vector graphics production?
I'm mainly interested in SVG, but other formats (such as pdf, eps, gs, etc) are good as well.
Thanks in advance for any help.
Bye, Ivano.
Vector graphics
5342 5 6- berserk
- 6 posts
- malbrecht
- 806 posts
Moin,
depends on what you consider “vector graphics production”, since almost everything you do in Houdini *is* vector graphics production.
Writing a postscript (for EPS or PDF) could be done as a shader, the same goes for SVG. As far as I know there is no “official” export for these formats, though. You could (easily) convert 3d object formats into SVG using an external conversion tool or, as mentioned, write your own exporter/shader.
But I *think* this is not the kind of response you are looking for. In the end, I think, what you need is some kind of render/shader output, not so much something “Houdini-internal”.
Marc
Marc
Good bye.
Good bye.
- berserk
- 6 posts
- Konstantin Magnus
- 670 posts
It apparently has been done and can be done in a Python SOP:
https://www.sidefx.com/forum/topic/28764/?page=1#post-131959 [sidefx.com]
GrayOlorin wrote this:
def exportSVG(): geo = hou.pwd().geometry() node = hou.pwd() filename = node.evalParm("location") sizeMult = node.evalParm("sizeMult") setColor = node.evalParm("setColorFromAttr") colorAttr = node.evalParm("colorAttr") addStroke = node.evalParm("addStroke") strokeColorR = node.evalParm("strokeColorr") strokeColorG = node.evalParm("strokeColorg") strokeColorB = node.evalParm("strokeColorb") strokeThickness = node.evalParm("strokeThickness") import xml.dom.minidom as minidom svgFile = minidom.Document() svgElement = svgFile.createElement("svg") svgFile.appendChild(svgElement) # Add code to modify the contents of geo. for prim in geo.prims(): positionString = "" for vertex in prim.vertices(): position = vertex.point().position() positionString = positionString + (str(position[0]*sizeMult) + "," + str(position[1]*sizeMult*-1) + " ") #now write to SVG polygonElement = svgFile.createElement("polygon") polygonElement.setAttribute("points", positionString) #Set Fill if (setColor == 1): color = prim.attribValue(colorAttr) red = hou.expandString("`inttohex(round(" + str(color[0]*255) + "))`") green = hou.expandString("`inttohex(round(" + str(color[1]*255) + "))`") blue = hou.expandString("`inttohex(round(" + str(color[2]*255) + "))`") hex = "#" + red[6:8] + green[6:8] + blue[6:8] polygonElement.setAttribute("fill", hex) else: polygonElement.setAttribute("fill", "None") #Set Stroke if (addStroke == 1): red = hou.expandString("`inttohex(round(" + str(strokeColorR*255) + "))`") green = hou.expandString("`inttohex(round(" + str(strokeColorG*255) + "))`") blue = hou.expandString("`inttohex(round(" + str(strokeColorB*255) + "))`") hex = "#" + red[6:8] + green[6:8] + blue[6:8] polygonElement.setAttribute("stroke", hex) polygonElement.setAttribute("stroke-width", str(strokeThickness)) svgElement.appendChild(polygonElement) #print svgFile.toprettyxml(indent=" ") #print filename newFile = open(hou.expandString(str(filename)),"w") newFile.write(svgFile.toprettyxml(indent=" "))
- _Christopher_
- 761 posts
- FakePilot
- 24 posts
