Finally getting some time to dip a toe into houdini, transitioning from soft, and the completely different way of working is giving my brain a much needed workout out, but I've a constant stream of questions and this one I've not been able to answer.
I'm trying to shade some transparent objects, like a sheet of glass but the shadows that are cast by it are black. I'm using H16, the mantra-pbr engine and the principled shader with an area light. Transparent shadows are on in the light, and i can see straight through the glass sheet to the shadow underneath, which is black.
Does this sound familiar? What am I doing wrong?
cheers,
A>
my shadows through glass are black.
9494 7 1- Andi Farhall
- 115 posts
- dlee
- 418 posts
- Andi Farhall
- 115 posts
- Andi Farhall
- 115 posts
- robsdesign
- 236 posts
Hi, I decided to setup a test file to help explain and also ask a question related to transparency/caustics.
I very rarely use faux caustics but it depends on the scene really. For something like this example, I've used All paths and compared to photon maps. (caustic light)
All paths can be found on the Mantra render node on the Rendering > Shading tab, Allowable paths. This allows you to render caustics without using photon maps but it tends to be noisy.
Using a caustic light to generate photon maps will produce less noise but will take longer. You can reduce the time by using the Light Mask section and removing lights. (I've shown this on the example picture)
I've used the Mantra Surface Shader (SHOP) as that's what I'm used to. I tried using the Principled Shader (MAT) but as you can see from the result, the glass is not red and I'm unsure why. I'm sure that I'm missing something and I'd be grateful if someone can explain.
Rob
Rob
- dlee
- 418 posts
Transmission colour (and nested dielectrics features) on the principled shader will not work in “Physically based rendering” mode unless you enable it explicitly on the mantra ROP (rendering->shading->“enable absorption and nested dielectrics”).
It doesn't seem to affect the colour of photon maps however - that might be a bug. I'll file a bug report.
- robsdesign
- 236 posts
- Andi Farhall
- 115 posts
