- Hey guys, looking for this, is there a way?
Thanks,
-Is there a way to archive a scene with all these dependency, textures and models input….?
vincent*
________________________________________________________________
Vincent Thomas
Lead LookDev Lighting / Senior Matte Painter & Creative Since 1998
How to output the UV channel created by the UV triplanar node? and few other important questions for the magicians....
3226 8 1- vinyvince
- 255 posts
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
- 7737 posts
- vinyvince
- 255 posts
As it etablish a relation between each vertex in space and a corresponding 2d pixel, i thought this was enough to obtain a UV layout as splitted it might looks… I guess im wrong in my understanding what uv map really means mathematically…
vince*
vince*
- 8525 posts
it's just that triplanar projection is not creating one texture space which you can use to map an image to
it creates 3 spaces then applies 3-6 textures to and blends them based on facing ratio between those axes and supplied normals
so if you want to bake that, you'd have to create 3 uv maps and 3-6 masks for your textures, which you can do if you want by directly outputting relevant data from triplanar projection node to some attributes
Edited by tamte - March 29, 2017 18:57:17
- vinyvince
- 255 posts
thanks make sence…
Is there any way toarchive a hip file with all these dependencin?
Is there also any spreadhsheet available concerning images being used?
Do you guys know?
Do you guys know?
- KaiStavginski
- 637 posts
- vinyvince
- 255 posts
Nothing specfic, just want to pack an houdini archive of my scene with no more outside references… See what i mean?
- Olaf Finkbeiner
- 323 posts
- vinyvince
- 255 posts
Anyone ? than how to have a list of all images with path being used in the current loaded scene?
cheers
cheers
