Cloth tearing in Houdini 16
7594 8 3- ajk48n
- 31 posts
Are there any examples of how cloth tearing and fracturing work in Houdini 16? When clicking on “Enable Tearing” on the cloth solver and “Enable Fracturing” on the cloth object, my cloth with teach all of its polygons individually apart.
From what I understand, I should be able to affect this by adding a fractureapart attribute however this doesn't seem to affect anything.
Also, the docs don't actually make any reference to the Fracturing tab on the Cloth Object.
Does anyone have any ideas?
I've attached a simple example file of where I was able to get to.
Edited by ajk48n - March 30, 2017 12:38:47
- michiel
- 428 posts
An important fracturing bug was fixed in 16.0.562, so be sure to get this version of Houdini 16, or newer.
For the rest, it's just a matter of playing with the Fracture Threshold parameter on the Cloth Object to get the desired behavior. I'd go up to, say 10000 in this example.
About the fracturepart attribute, make sure it's called “fracturepart” and make it a primitive attribute.
Alternatively, you can simply make use of the Solid Fracture tool, which was designed to work for the Solid Object but also happens to work for the Cloth Object.
I'm attaching a version of your file in which I made these changes.
- ajk48n
- 31 posts
- JOHN c
- 8 posts
- edward
- 7694 posts
- gswartz
- 24 posts
- Michela Ledwidge
- 12 posts
gswartz, I think the way to do this is to set fracturepart attribute for the prims on either side of the line you've created in points. Looking at the Solid Fracture attributes it is working with prims not points.
I've attached a hip that explicitly sets fracturepart for a group of primitives but I can't work out how to set the tear threshold or interoperate with solid fracture. I think the idea is that you can modify the solid fracture DA yourself but I haven't delved that far yet.
All, is there a tear threshold attribute you can set per prim?
- michiel
- 428 posts
- Tim Sun
