Hi everyone,
I'm looking for advice on best practices in Houdini when joining a team. I'm interested mostly in things that advanced Houdini users would want juniors to know. Things like organization of the node graph, common naming techniques, etc.
Both positive skills to have, as well as things that may be annoying (like having a huge node graph with no arrangement or notes about how it works)
I've looked around online for this but mostly just found tutorials for beginners. I'm more interested in what common improvements or mistakes a junior might make within a production environment.
Best practices within Houdini
3749 5 1- ajk48n
- 31 posts
- Olaf Finkbeiner
- 323 posts
Hi there,
not using $HIP file-locations but hardcoded file paths is definitely one of them.
Not useing sticky pads to explain things in the node tree.
The use of a null node as OUT_xxx is also quite common and i would strongly recommend it.
Doing things manually with a edit(poly)/Group node etc., that you can do in a procedural way.
Even if your result is only needed once (you never know!).
Not using an HDA where it could be used, instead of the same code copied over and over again.
Not setting up parameter/menus/ui… create an interface
just a few of the top of my head…
kind regards
Olaf
kind regards
Olaf
- Cyzor
- 181 posts
Some useful network-specific recommendations are available in the Houdini 15.5 docs, if you haven't seen them. Written by Ari “Particle Kabob” Danesh, I believe.
http://www.sidefx.com/docs/houdini15.5/network/best_practices [sidefx.com]
- Konstantin Magnus
- 670 posts
Do you think “node as prefix” is still necessary in H16?
- 7658 posts
- ajk48n
- 31 posts
