Hello!
I'm having an issue whenever i build anything with hcustom, it crashes in the build. I have VS 2015, but it still crashes
Any help would be great to figure out why nothing is compiling…
also if possible, where do I put the custom IMG_File object to show up in the editor? Having issues with that as well
I have two images below. trying to make the .raw file type appear, but it doesn't show in the drop menu for the textures still as well.
hcustom keeps crashing when building
2303 3 1- CHADALAK1
- 6 posts
- edward
- 7709 posts
- CHADALAK1
- 6 posts
edward
I found a solution to this. Before running hcustom, set the environment variable TBBMALLOC_PROXY_ENABLE to 0.
WARNING: Do NOT leave this set when running Houdini! I've seen 5x slow downs with this enabled.
That's soo weird… Is it a memory leak that happens with hcustom?
I'll try this after work today. This should create the proper DLLs? Also when I want to add the custom IMG_File class, should i place the created files anywhere in particular?
Update: Gave it a quick try. Went to PC->Properties->Advanced Settings->Environment Variables..No such luck. I set the environment variable to this.
Update 2: My complete bad… I set it to User based Variable instead of System Variable… now it works and does not crash !!
Next step is to figure out how to have the custom IMG_File class to appear in the drop menu when selecting a texture …
Edited by CHADALAK1 - June 29, 2017 17:00:05
- mtucker
- 4435 posts
