This is a weird one… trying to use cache SOP in H16. First one I lay down, only has a few parms, none of them are “index,” “blend position.” I thought it might have been replaced by something else, (I want to frame blend a file read to get in-between frames), but couldn't find anything.
Then I went back to another instance of a cache SOP and magically all of the parms are there. If I lay down a new one, only 5 parms are there. I have no idea how this other cache sop got made or all of the rest of the parms exposed, but the only way to re-create it is to copy/paste. I checked and they are both defined by the same sop/cache node in $HFS. If I go to “edit parm interface” on either of the nodes, all of the parms I expect are there, but as I said, they don't show up on new instances.
Sorry, can't provide screen shots, too much security here!
Anyone else see this? This is H16.0.633
Sean
