It's been a while since I've created any Digital Assets.
I think I may have forgotten how to do some things with them.
I have a digtial asset that I wanted to change a couple of its' parameters default values; When say you open a new hip file and import/create that digital asset.
In the past, and this is where I think I fail to remember, I thought I could simply do the steps:
Allow editing of contents > Change the digital assets parameter values to desired ones > Save Node Type > Match Current Definition.
But it doesn't change/save to my changes as expected.(When I import/create in a new file - the old parameter values persist)
The only way to get what I want is to delete those digital asset parameters, find the ‘source’ parameter and delete the channel reference that got created when the asset was made; Then put in the value I wish it to be at. Drag and Drop the newly set parameter for the asset like originally. Then save node type and match current definition.
At this point if I then import/create the asset I do get the desired results with the ‘new’ parameter values.
I don't mind taking these extra steps but I swear I thought I could simply change the values, save node type and match current definition.
Any thoughts, am I missing something?
Digital Asset - Save Node Type
3082 2 0- BabaJ
- 2036 posts
- goldfarb
- 3455 posts
- BabaJ
- 2036 posts
