My first attempt at using the auto-rig toolset is with a model in a T-Pose. All the preview/tutorial videos I've found so far start with models whose arms are out to the side and most of the way down - almost in perfect alignment with the default auto-rig setup - requiring very little adjustments to shoulders, elbows, wrists, or fingers
After trying to maneuver all the rig pieces from their defaults to their appropriate places in the T-Pose setup and clicking the “Generate Rig” button, things don't work as desired - and are a very far cry from the magical results I've seen in the videos (especially with the hands - those are completely messed up).
Are there any autorig tutorials available that start with a T-Pose, and discuss the ‘gotchas’ one will face when autorigging this sort of setup?
Thanks,
Luke
Auto-Rigging a T-Pose Model
3600 12 1- Luke Letellier
- 240 posts
- goldfarb
- 3455 posts
- Luke Letellier
- 240 posts
Here's the mesh:
https://www.dropbox.com/s/11odz6bo0m5b01g/Human_01.bgeo.sc?dl=0 [www.dropbox.com]
There must be something that I'm doing incorrectly or that I'm missing altogether.
Edited by Luke Letellier - Jan. 5, 2018 17:27:35
- goldfarb
- 3455 posts
- Luke Letellier
- 240 posts
Wow, that came out a lot better than mine. I must be doing something incorrectly.
Perhaps I'm just not being as particular/exact with joint placement before generating/finalizing the rig? How long did you spend rearranging the joints?
Once thing I noticed when looking at the hands in your rig were that the square finger joint/nulls were all aligned perfectly to the fingers, whereas when I was trying to align them to the hand mesh, it wouldn't let me rotate the squares at all.
Edited by Luke Letellier - Jan. 8, 2018 21:26:54
- goldfarb
- 3455 posts
- Luke Letellier
- 240 posts
- Luke Letellier
- 240 posts
Making progress this time around! Thumbs still need some work, but the other fingers are much better.
Question regarding the legs/knees - is there a way to adjust them so that the knees don't bow outwards or invert when the foot is raised up? My guy will be inside a truck, and I'd like the knees to stay on the same plane as the hips and feet as the latter moves upwards.
Less of this:
More of this:
Thanks again!
Luke
Less of this:
More of this:
Thanks again!
Luke
- goldfarb
- 3455 posts
- Luke Letellier
- 240 posts
- Luke Letellier
- 240 posts
Is there a way to save your pre-baked rig so that after some thorough testing you discover that the resulting rig isn't ideal, you can easily load up the un-baked version, make a small tweak, and then rebake it? And i that doesn't work, load up the un-baked rig again, make another tweak, etc?
Luke
Luke
- goldfarb
- 3455 posts
the Autorigs saves all the setting into the HDA (in the python File>Save, or when you Generate the rig)
now you can do File > New From HDA and select the first rig you made to make a new version based on the first one.
I cover this in the Masterclass: https://www.sidefx.com/tutorials/autorigging-masterclass/ [www.sidefx.com]
- Luke Letellier
- 240 posts
