Hi guys, I have problems with the menus in Houdini and I do not know what to do anymore.
I attached images and other information. I would be very grateful if you know the solution to this or if it happens to someone else.
Thank you very much.
Houdini FX Version 16.5.378
Platform: Windows 10.0.10586
Operating System: Windows 10 Pro x64
Qt Version: 4.8.5
Number of Cores: 8
Physical Memory: 31.94 GB
Number of Screens: 2
Screen 0: 1920 x 1080 at 0,0
Work Area 0: 1920 x 1040 at 0,0
Screen 1: 1920 x 1080 at 1920,0
Work Area 1: 1920 x 1040 at 1920,0
OpenGL Vendor: NVIDIA Corporation
OpenGL Renderer: GeForce GTX 1080/PCIe/SSE2
OpenGL Version: 4.5.0 NVIDIA 378.66
OpenGL Shading Language: 4.50 NVIDIA
Detected: NVidia Consumer
8192 MB
378.66.0.0
Supported Extensions not in OpenGL 3.3 (Version):
EXT_extensions_string
GL_ARB_base_instance (4.2)
GL_ARB_bindless_texture
GL_ARB_buffer_storage (4.4)
GL_ARB_compatibility
GL_ARB_compute_shader (4.3)
GL_ARB_debug_output
GL_ARB_gpu_shader5 (4.0)
GL_ARB_gpu_shader_fp64 (4.0)
GL_ARB_multi_bind (4.4)
GL_ARB_program_interface_query (4.3)
GL_ARB_robustness
GL_ARB_sample_shading (4.0)
GL_ARB_separate_shader_objects (4.1)
GL_ARB_shader_image_load_store (4.2)
GL_ARB_shader_storage_buffer_object (4.3)
GL_ARB_shading_language_packing (4.2)
GL_ARB_tessellation_shader (4.0)
GL_ARB_texture_buffer_object_rgb32 (4.0)
GL_ARB_texture_filter_anisotropic (4.6)
GL_ARB_transform_feedback3 (4.0)
GL_ARB_vertex_attrib_64bit (4.1)
GL_EXT_abgr
GL_EXT_blend_minmax
GL_EXT_direct_state_access
GL_KHR_debug (4.3)
GL_NVX_gpu_memory_info
GL_NV_gpu_shader5
WGL_EXT_swap_control
Unsupported OpenGL Extensions used by Houdini:
GL_ATI_meminfo
OpenGL Limits:
ELEMENTS_VERTICES 1048576
ELEMENTS_INDICES 1048576
VERTEX_UNITS 32
TESS_CONTROL_TEXTURE_IMAGE_UNITS 32
TESS_EVALUATION_TEXTURE_IMAGE_UNITS 32
GEOMETRY_UNITS 32
FRAGMENT_IMAGE_UNITS 32
COMBINED_UNITS 192
TEXTURE_SIZE 32768
3D_TEXTURE_SIZE 16384
CUBE_MAP_TEXTURE_SIZE 32768
RECTANGLE_TEXTURE_SIZE 32768
TEXTURE_ARRAY_LAYERS 2048
MAX_COLOR_TEXTURE_SAMPLES 32
MAX_DEPTH_TEXTURE_SAMPLES 32
FBO_ATTACHMENTS 8
DRAW_BUFFERS 8
VIEWPORT_DIMS 32768x32768
VERTEX_UNIFORMS 4096
FRAGMENT_UNIFORMS 4096
VERTEX_ATTRIBS 16
VERTEX_OUTPUT_COMPONENTS 128
MAX_CLIP_DISTANCES 8
PATCH_VERTICES 32
TESS_GEN_LEVEL 64
TESS_PATCH_COMPONENTS 120
TESS_CONTROL_OUTPUT_COMPONENTS 128
TESS_CONTROL_TOTAL_OUTPUT_COMPONENTS 4216
TESS_EVALUATION_OUTPUT_COMPONENTS 128
GEOMETRY_UNIFORM_COMPONENTS 2048
GEOMETRY_INPUT_COMPONENTS 128
GEOMETRY_OUTPUT_COMPONENTS 128
GEOMETRY_TOTAL_OUTPUT_COMPONENTS 1024
GEOMETRY_OUTPUT_VERTICES 1024
UNIFORM_BLOCKS 84
UNIFORM_BLOCK_SIZE 65536
UNIFORM_BUFFER_BINDINGS 84
COMBINED_VERT_UNIFORM_BLOCKS 14
COMBINED_VERT_UNIFORM_COMPS 233472
TESS_CONTROL_UNIFORM_BLOCKS 14
TESS_CONTROL_UNIFORM_COMPONENTS 2048
TESS_EVALUATION_UNIFORM_BLOCKS 14
TESS_EVALUATION_UNIFORM_COMPONENTS 2048
COMBINED_GEO_UNIFORM_BLOCKS 14
COMBINED_GEO_UNIFORM_COMPS 231424
COMBINED_FRAG_UNIFORM_BLOCKS 14
COMBINED_FRAG_UNIFORM_COMPS 233472
MAX_FRAGMENT_STORAGE_BLOCKS 16
MAX_STORAGE_BLOCK_BINDINGS 96
TRANSFORM_FEEDBACK_INT_COMPS 128
TRANSFORM_FEEDBACK_SEP_COMPS 4
TRANSFORM_FEEDBACK_SEP_ATTRIBS 4
LINE_WIDTH_RANGE 0.5 - 10
LINE_WIDTH_GRANULARITY 0.125
POINT_SIZE_RANGE 1 - 189.875
POINT_SIZE_GRANULARITY 0.125
OpenCL Platform NVIDIA CUDA
Platform Vendor NVIDIA Corporation
Platform Version OpenCL 1.2 CUDA 8.0.0
OpenCL Device GeForce GTX 1080
OpenCL Type GPU
Device Version OpenCL 1.2 CUDA
Frequency 1822 MHz
Compute Units 20
Device Address Bits 64
Global Memory 8192 MB
Max Allocation 2048 MB
Global Cache 320 KB
Max Constant Args 9
Max Constant Size 64 KB
Local Mem Size 48 KB
2D Image Support 16384x32768
3D Image Support 16384x16384x16384
OpenCL Platform Extensions:
cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
cl_khr_fp64
cl_khr_byte_addressable_store
cl_khr_icd
cl_khr_gl_sharing
cl_nv_compiler_options
cl_nv_device_attribute_query
cl_nv_pragma_unroll
cl_nv_d3d10_sharing
cl_khr_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_copy_opts
OpenCL Device Extensions:
cl_khr_fp64
cl_khr_icd
cl_khr_gl_sharing
cl_nv_pragma_unroll
cl_nv_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_copy_opts
Environment:
ACTIVETAKE Main
ADSK_3DSMAX_x64_2017 C:\Program Files\Autodesk\3ds Max 2017\
ADSK_3DSMAX_x64_2018 C:\Program Files\Autodesk\3ds Max 2018\
ADSK_CLM_WPAD_PROXY_CHECK FALSE
ALLUSERSPROFILE C:\ProgramData
APPDATA C:\Users\PC\AppData\Roaming
CLASSPATH .;CPROGRA~1/SIDEEF~1/HOUDIN~1.378/houdini/scripts/java/sesi.jar
COMPUTERNAME PC-PC
ComSpec C:\WINDOWS\system32\cmd.exe
CommonProgramFiles(x86) C:\Program Files (x86)\Common Files
CommonProgramFiles C:\Program Files\Common Files
CommonProgramW6432 C:\Program Files\Common Files
FPS_BROWSER_APP_PROFILE_STRING Internet Explorer
FPS_BROWSER_USER_PROFILE_STRING Default
FP_NO_HOST_CHECK NO
H CPROGRA~1/SIDEEF~1/HOUDIN~1.378
HB CPROGRA~1/SIDEEF~1/HOUDIN~1.378/bin
HD CPROGRA~1/SIDEEF~1/HOUDIN~1.378/demo
HFS CPROGRA~1/SIDEEF~1/HOUDIN~1.378
HH CPROGRA~1/SIDEEF~1/HOUDIN~1.378/houdini
HHC CPROGRA~1/SIDEEF~1/HOUDIN~1.378/houdini/config
HIP CUsers/PC
HIPFILE CUsers/PC/untitled.hip
HIPNAME untitled
HOME CUsers/PC/Documents
HOMEDRIVE C:
HOMEPATH \Users\PC
HOUDINI_DESKTOP_DIR CUsers/PC/Desktop
HOUDINI_OGL_SOFTWARE 1
HOUDINI_OS Windows
HOUDINI_QT_PREFERRED_BINDING PySide
HOUDINI_TEMP_DIR CUsers/PC/AppData/Local/Temp/houdini_temp
HOUDINI_USER_PREF_DIR CUsers/PC/Documents/houdini16.5
HOUDINI_USE_HFS_PYTHON 1
HOUDINI_VERSION 16.5.378
HSITE CPROGRA~1/SIDEEF~1/HOUDIN~1.378/site
HT CPROGRA~1/SIDEEF~1/HOUDIN~1.378/toolkit
HTB CPROGRA~1/SIDEEF~1/HOUDIN~1.378/toolkit/bin
INTEL_DEV_REDIST C:\Program Files (x86)\Common Files\Intel\Shared Libraries\
JOB CUsers/PC
LOCALAPPDATA C:\Users\PC\AppData\Local
LOGONSERVER \\PC-PC
MIC_LD_LIBRARY_PATH C:\Program Files (x86)\Common Files\Intel\Shared Libraries\compiler\lib\mic
NUMBER_OF_PROCESSORS 8
OS Windows_NT
OneDrive C:\Users\PC\OneDrive
PATH CPROGRA~1/SIDEEF~1/HOUDIN~1.378/python27;CPROGRA~1/SIDEEF~1/HOUDIN~1.378/bin;CPROGRA~1/SIDEEF~1/HOUDIN~1.378/toolkit/bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\ProgramData\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Skype\Phone\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\Common Files\Autodesk Shared\;C:\Program Files (x86)\Autodesk\Backburner\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Users\PC\AppData\Local\Microsoft\WindowsApps;
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
POSE CUsers/PC/Documents/houdini16.5/poselib
PROCESSOR_ARCHITECTURE AMD64
PROCESSOR_IDENTIFIER Intel64 Family 6 Model 158 Stepping 9, GenuineIntel
PROCESSOR_LEVEL 6
PROCESSOR_REVISION 9e09
PSModulePath C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC C:\Users\Public
PYTHONHOME CPROGRA~1/SIDEEF~1/HOUDIN~1.378/python27
ProgramData C:\ProgramData
QT_OPENGL_DEBUG_CONTEXT 0
QT_OPENGL_ENABLE_RETINA 0
RF_2015_PATH D:\Archivos de Programa\RealFlow 2015
SESSIONNAME Console
SystemDrive C:
SystemRoot C:\WINDOWS
TEMP CUsers/PC/AppData/Local/Temp/houdini_temp
TMP C:\Users\PC\AppData\Local\Temp
USER PC
USERDOMAIN PC-PC
USERDOMAIN_ROAMINGPROFILE PC-PC
USERNAME PC
USERPROFILE C:\Users\PC
asl.log Destination=file
windir C:\WINDOWS
windows_tracing_flags 3
windows_tracing_logfile C:\BVTBin\Tests\installpackage\csilogfile.log
Problems of viewing with the menus in houdini apentice 16
1241 1 2- pardos1932
- neil_math_comp
- 1743 posts
Looks like a graphics driver issue. Apparently 381 fixed some issues in the 378.66 you have now. Try upgrading to a more recent one. (I'm on 388.16)
