Hi All,
Is it at all possible to promote attributes inside a Attribute wrangle SOP . ie promote a point attribute to a detail attribute at the end of the vex code ? . If so Id love an example.
Rob
Q: Attribute wrangle > Attribute promote
15709 27 3- circusmonkey
- 2624 posts
- 8531 posts
it really depends on what you are promoting
but let's say you want to promote Point or Prim to Detail
then set Attrib Wrangle to Point or Prim mode and use setdetailattrib();
so prototype would be setdetailattrib(0, “detailattribname”, attrib or per element value to promote, “promotion method”);
so for example:
setdetailattrib(0, “ymax”, @P.y, “max”);
setdetailattrib(0, “areasum”, @area, “add”);
etc. but for that your detail attrib has to already exist
in theory you can do :
adddetailattrib(0, “ymax”, 0);
to even create the attrib within the same wrangle, but for some reason it doesn't work for me, maybe because wrangle code becomes part of the snippet function and maybe addattrib() has some problems with that, it just creates the attrib, but setattrib() doesn't change the default value, which is quite surprising
so so far you'l probably have to create attrib before, or do it in Attrib VOP where addattrib/setattrib combo works
and of course you can run it in opposite way as well, so Attrib Wrangle in Detail mode and loop through all components to compute promoted value, then just bind export it to detail attrib
so for example:
- circusmonkey
- 2624 posts
Thanks so much for the answer, straight into the notebook, while I have you here in the attribute wrangle how to I set a vector as .x .y .z in vex ? .
ie v@initialvel = set(@v.x,@v.y,@v.z); . In the spreadsheet my @initialvel is listed as 0 ,1 , 2 and not x y z
Rob
Rob
Gone fishing
- 8531 posts
- circusmonkey
- 2624 posts
- 8531 posts
setattribtypeinfo(0, “point”, “initialvel”, “vector”);
or of course for this particular case
v@initialvel = @v;
as 3@ is matrix3 attribute, not float 3
EDIT: ignore this, it was for the question before you changed it, I forgot to refresh
v@initialvel = @v;
- circusmonkey
- 2624 posts
- jlait
- 6179 posts
tamte
This works. But unfortunately it determines what type of attribute to make by the type of your value. 0 defaults to integer, not float, so you create an integer.
adddetailattrib(0, “ymax”, 0.0);
will work as the 0.0 forces it to float.
- Konstantin Magnus
- 670 posts
What´s the reason setting detail attributes works for “max”, but not for “min”?
“min” stays at -123.0, while “max” returns something usable.
adddetailattrib(0, "dist_min", -123.0); setdetailattrib(0, "dist_min", @dist, "min"); adddetailattrib(0, "dist_max", -123.0); setdetailattrib(0, "dist_max", @dist, "max");
- BabaJ
- 2036 posts
It is usable, just have to consider the context and adjust the code accordingly.
min and max will only use the range from 0 to the smallest negative number or 0 to largest postive number.
Then the results will make sense:
for a value >= 0 max will be the largest number, while min will be zero.
for a value <= 0 max will be zero and min will be the smallest negative number.
- 8531 posts
BabaJ0 intrinsically doesn't play any role in min and max
it's just min or max of all the numbers, so unless 0 is one of the numbers and is minimum or maximum from the set of numbers, it doesn't affect your result
(in above cases it comes down to default value or incoming detail attrib value as one of those may be 0 which may confuse you into thinking that 0 somehow plays the role in min/max)
Konstantin Magnusbe careful what you initialize the detail attribs to
if your default for “dist_min” is -123.0 and no @dist value is smaller, your “dist_min” stays -123.0, so you may want to set its default value higher than any possible point values
the same for max, you may want to initialize it to be lower
if you don't want to be tempering with default value of the attrib, you can as well just set those initial attribute values before this wrangle and avoid adddetailattrib() altogether
also note that adddetailattrib() may not be necessary if you are ok with default value to be 0 as setdetailattrib() will now automatically create missing attribs
Edited by tamte - April 25, 2018 11:23:32
- Konstantin Magnus
- 670 posts
tamte
Alright, great! I mistakenly expected the initial value to be overwritten in just any case.
But something like this is way more convenient and sufficient in my case:
float height = @P.y; setdetailattrib(0, "height_min", height, "min"); setdetailattrib(0, "height_max", height, "max");
Thank you!
- 8531 posts
- BabaJ
- 2036 posts
- Konstantin Magnus
- 670 posts
tamte
just be careful as now your default value is 0 so you will get into situation where 0 will be your min if all @P.y are > 0 and 0 may be your max if all @P.y < 0
so not really the safest
You are correct, my quick example was misleading. Here is a real use case, that should do its job:
// measures point distances f@dist = 0.0; int near_pts[] = pcfind(0, "P", @P, 1.0, 32); foreach(int pt; near_pts){ @dist += distance( @P, point(0, "P", pt) ); } @dist /= len(near_pts); adddetailattrib(0, "dist_min", 1e7); adddetailattrib(0, "dist_max", -1e7); setdetailattrib(0, "dist_min", @dist, "min"); setdetailattrib(0, "dist_max", @dist, "max");
And a visual range mapper:
float min = detail(0, "dist_min", 0); float max = detail(0, "dist_max", 0); float range = fit(@dist, min, max, 0, 1); @Cd = hsvtorgb( set( range, 1, 1) );
tamteI would not want to spend extra nodes for this and find it more elegant to include it (if it works).
any reason for not using Attribute Promote?
Here is the HIP-file in case anyone is interested:
Edited by Konstantin Magnus - April 25, 2018 17:41:42
- Wren
- 527 posts
- BabaJ
- 2036 posts
You could use the pointvertices() function that returns a list of vertices belonging to the point.
Decide which vertice you want to use and get its attribute with vertex()/vertexattrib() and assign that value to the point with setpointattrib().
Similarly going from point to prims.
Functions list on this page.
http://www.sidefx.com/docs/houdini/vex/functions/index.html [www.sidefx.com]
in the filter box just type point, prim or vert to narrow the search
Edited by BabaJ - April 25, 2018 14:57:03
- 8531 posts
- Konstantin Magnus
- 670 posts
tamteOh yes, thank you, I corrected it in the example above.
you probably want -1e7 which is -10000000
- Wren
- 527 posts
BabaJ
Thank you for painting the broad strokes.I appreciate it.
Though, I am still chewing on loops to get them down pat. Does someone suppose they could show the structure how they would loop through all that in vex please?
soho vfx
