View more then one attribute using visualizer ?
1281 2 1- _Christopher_
- 761 posts
- CYTE
- 678 posts
- _Christopher_
- 761 posts
This is the problem I have; I hope someone can answer.
When creating a primitive wrangler within a forLoop SOP and that primitive wrangler contains an attribute must you have the forLoop end block SOP node selected for it to work, not the primitive wrangler, within the forLoop SOP, correct ?
Also can you create a detail attribute variable within a primitive wrangler and expect it to work ?
【T】【C】【S】
