I'm trying to grasp the concepts/ideas behind sampling certain elements in a frame higher than others.
Under Geometry > Render > Dicing:
This does not affect standard shading when rendering Physically Based Rendering, correct?
Any input welcome!
thanks!
Mantra: Higher sampling higher per material or object
1151 2 0- deadalvs
- 196 posts
- Olaf Finkbeiner
- 323 posts
to start with have a look at this:
http://www.sidefx.com/docs/houdini/props/index.html [www.sidefx.com]
You can set various render properties at object level, but you will have to “expose” them first…
greetings
Olaf
greetings
Olaf
- deadalvs
- 196 posts
