When I click render, it only rendered the last node which called “rslight6”.
It works in mantra and arnold, but not in redshift.
Anyone knows why and how to fix?
Thanks a lot.
Redshift Multiple render nodes issue: Can't render them once with Merge node or connections.
6741 4 1- Weslie Sison
- 8 posts
- TwinSnakes007
- 604 posts
- Jimbo55
- 54 posts
- howitzer99
- 6 posts
The “Non-Blocking Current Frame Rendering” option is in the ROP Main tab, near the bottom.
Also, when you running the render outputs, make sure “This Node and All Inputs” is enabled in Render Options. To get to this, go to the bottom ROP in the chain and click the Render flag. A Render options dialog box will pop-up and in the Dependency Rendering Settings you'll see the drop-down mentioned above. Also note that the dependency section will be disabled unless there are other connected ROPs.
Hope this helps.
Hope this helps.
Edited by howitzer99 - March 20, 2019 22:27:16
- Weslie Sison
- 8 posts
