I hear the term ‘cusp normals’ a lot.
Can someone explain to me what this is/what this means how I do it and why it is done?!
Thanks.
Cusp Normals
5338 6 4- pip31
- 17 posts
- sl0throp
- 258 posts
Basically you cusp your normals with a facetSop..if you are familiar with other packages it is like smoothing angle.
If you are not that familiar with modeling, it was allows edges to be soft or hard and to define the smoothing angle. The best way to see it clearly is create a box and render it…You will see that the surfaces have a gradated look rather than looking hard edged.
Now append a facetSop, turn on cusp and set the angle to 0 and make sure “post compute normals” is clicked on at the bottom. it should be clear what the difference is.
so the number represents the angle at which something will be shaded smooth or hard 0 all edges are hard. If you had a bevels this would make the bevels look faceted, so you would try another angle, like 22-45 or something.
- symek
- 1390 posts
- sl0throp
- 258 posts
- circusmonkey
- 2624 posts
- Dav_Rod
- 40 posts
- Konstantin Magnus
- 670 posts
And the VEX way of cusping vertices would be presumably this:
v@N = prim_normal(0, @primnum, 0, 0, 0);
