Animate a tube following a curve
   2335   5   1
Hello
How can I animate a tube growing and following a curve? I have tried Polyextrude but it does not behave the way I want.
Gz
Houdini gamboler
plenty of ways to skin a cat, but an animated carve sop could be a good way to achieve this.
here's an example
Edited by brianBurke - Sept. 17, 2018 12:00:08
bb_anim_tube_v001.hip (119.5 KB)
Wow amazing! Thanks a lot for your example file and your time
In the carve node, if I delete channels and animate only “second V”, I get exactly what I wanted.
Some questions if you don't mind :
Whats the use of the Polyframe node, and the normal_and_up_vector VOP?
Good day
Gz
Houdini gamboler
cheers gz. the polyframe and the vop are creating a normal and up-vector for the copy-to-points sop to use to align the circles along the curve.
Thanks Brian. I have some more questions if you don't mind.
1: How can I cap the ends of the tube? Since the points are not the same at both ends , as they are built during the tube's travel along the curve, how can I specify edges to cap holes?
David
Houdini gamboler
Polycap node at the end will do you.
