Hello
I want to reuse the Spline Mesh Actor in the scene, but the Spline Mesh Actor can't be selected as a World Outliner Input data source.
Can't select Spline Mesh Actor as a World Outliner Input data source
3636 5 0- Seaton
- 22 posts
- MagnusL3D
- 1104 posts
In the Houdini Inputs, change the dropdown that says ‘World Outliner Input’ to ‘Curve Input’, that will use Houdini's own curve. Or you can make a editable Node inside your HDA that is a curve sop.
As far as I know that's how you are supposed to work and that the Spline Mesh Actor can't be used the way you want.
- Seaton
- 22 posts
MagnusL3DThe Spline Mesh Actor will be referenced by other HDA Actors or Blueprints, so can't use ‘Curve Input’ directly.
And making an editable Curve Node inside HDA does not work as expected, see also https://www.sidefx.com/forum/topic/58507/ [www.sidefx.com]
- dpernuit
- 534 posts
The World outliner input has the ability to read curves for unreal splines, but it's expecting an Actor with a Spline Component, not a Spline Mesh Component.
If you want to share curves between HDAs and Blueprint, using a World input with an Actor that has Spline components is the best way to do so, as that Actor can be shared between multiple HDAs.
- dpernuit
- 534 posts
- Seaton
- 22 posts
