Did i miss something is there still no option to archive a full project with all dependencies referenced files?
Also i would like to have an option to import an alembic camera and have a node to off set the animation instead of using expression $FF to offset the timing in my source file (which doesn't seem to work with the cam switcher) or use manually the animation editor… Make sense?
vince*
vince*
Vincent Thomas (Avalailable early summer 2017)
Senior Lighting Lookdev / Env DigiMatte Artist / Creative Designer VFX supervisor
Still no option to archive an Houdini project with all dependancies referenced files?
4312 6 3- vinyvince
- 255 posts
Edited by vinyvince - April 14, 2017 02:07:50
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
- Olaf Finkbeiner
- 323 posts
Hi Vince,
your request for an asset collector is understandable.
I think you need to setup your scenes in a way that makes this possible.
How would such a function deal with a node that cooks a simulation to disk? Would it fist have to cook the simulation?
So please explain what you need it for? Is if for archiving projects? Is it to clean up the mess you created when setting up the scene?
Re: camera
This again sounds easy and trivial. But it is not. I have written may scripts in my 3dsmax times exporting and importing cam settings between various packages. And yes it is a pain, but also here your request would solves your situation in this specific situation and not more.
kind regards
Olaf
Re: camera
kind regards
Olaf
- SreckoM
- 379 posts
- 3di2017
- 12 posts
- raistlinf
- 19 posts
- 3di2017
- 12 posts
raistlinf
http://mikedatsik.com/backup-houdini-project/ [mikedatsik.com]
Thanks, i'll give that a try when the need arises.
Is there anything similar to scriptspot for houdini?
- anon_user_40689665
- 648 posts
