Vellum Rest Blend not working
4768 3 2- NNois
- 174 posts
- 8522 posts
if your rest geometry is animated you have to use Vellum Rest Blend in DOPs so that it updates over time
however in your example I don't see it animate and you are using the same shape as rest that you used to generate constraints to begin with so there will be no change in rest attributes whatsoever anyway
EDIT: if the whole purpose is to maintain the shape then increase Bend Stiffness as stiffness defines how strong the constraint tries to return to rest, so no matter whether you want your rest to animate or not, if your stiffness is weak you will not see much effect of reaching the rest state if other forces acting on your hair are strong
Edited by tamte - Oct. 22, 2018 12:24:58
- ervin3d
- 3 posts
Hello Houdini community,
Has anyone succeeded to mix dynamically together the “Vellum Rest Blend” with the “Vellum Constraint Properties - Rest Length Scale”?
Its working for me only one or the other, it depends of dopnet1 / merge1 order (which Input Operator is on the top), the mixing is not working, although there is a sticky note which says:
“Wire Vellum Constraint Properties and Vellum Rest Blend to update constraints dynamically”
Any suggestion or idea is more than welcome. :-)
Edited by ervin3d - June 15, 2019 03:29:40
- Yader
- 33 posts
