I'm fairly new to Houdini so i'm testing its potential at the moment. I made a small tool to test how digital assets work in Unity. However, I can't see my own parameters in Unity…. for now I just ‘exposed’ the color into a parameter, but I can't even see that, let alone the test box that it's being applied on. I've also noticed that the Houdini installer installs HoudiniEngineUnity.unitypackage and not HoudiniEngineUnity_v2_beta.unitypackage, if that makes any difference.
No parameters in Unity
1752 4 0- esvil
- 13 posts
- seelan
- 571 posts
You attached a hip (scene) file with an HDA embedded inside. The Houdini Engine for Unity plugin only loads .hda files, so I've saved out the embedded HDA into its own .hda file. The new .hda file works when I load it into Unity via our plugin, and shows the color parameters. I think you were just missing that one step. I've attached the .hda file here.
HoudiniEngineUnity.unitypackage is the right package name (official release), so you're good there.
- esvil
- 13 posts
- seelan
- 571 posts
- esvil
- 13 posts
