Centos: xterm: command not found
   3830   2   0
Hi
ow can I fix this one, on a fresh centos install and houdini I get this when I want to open a shell window
sh: xterm: command not found
when I start houdini from a shell it logs stuff there, but if You close it it is quiet and You can not open a new one
thanks
Martin
Not sure whats going on here, are you trying to run xterm as root?
Xterm is an alternative terminal emulator.
Your best bet is to load gnome-terminal and then run houdini
/opt/hfs17.0/bin/{houdini,houdinifx,hindie} (pick whichever you want to run)
ah, just saw it, thank you
this gets logged soon as I try to open a shell inside houdini with Houdini>Windows>Shell
when running houdini from a terminal, all logs are in the terminal, but if You close it, they go nowhere.
is there a way to reopen a shell so You can read logs?
thanks
Martin
Edited by sanostol - Nov. 8, 2018 11:22:34
