Hi!
I'm making around 10 individual grass blades that I merged together so I could do non-overlaping UVs. Now, I'd like to save each grass blades separately with a different number in the file name.
I was thinking of doing: 1. use connectivity sop to split each grass blades by @class 2. use for-each loop to somehow export each with its @class in the naming.
I tried promoting the @class to detail and save with: folder/grass_blade.@class.bgeo That doesn't work and I'm just trying anything…
Any help is appreciated!
-Olivier
for each file save with @class in file naming
1293 3 0- olivierth
- 1004 posts
- olivierth
- 1004 posts
Solved!
Here's my solution. I took the @class and subtracted the @Frame from it. Then, I grouped it if the result was zero. Then, I just blasted what wasn't in that group. That way, I had a different grass blade at each frame:
i@group_visibleGrass = 0;
i@class -= int(@Frame)-1;
if(i@class == 0){
@group_visibleGrass = 1;
-Olivier
if(i@class == 0){
-Olivier
- goldfarb
- 3455 posts
- olivierth
- 1004 posts
