Custom Shelf Tools not wired/appended to selected geo/network node
2192 6 1- stu
- 246 posts
- goldfarb
- 3455 posts
- stu
- 246 posts
That strikes me as odd given that the auto-generated script appears to contain verbage for the connection.Simple colorSOP custom shelf tool script:
import sys
import toolutils
outputitem = None
inputindex = -1
inputitem = None
outputindex = -1
num_args = 1
h_extra_args = ‘'
pane = toolutils.activePane(kwargs)
if not isinstance(pane, hou.NetworkEditor):
pane = hou.ui.paneTabOfType(hou.paneTabType.NetworkEditor)
if pane is None:
hou.ui.displayMessage(
’Cannot create node: cannot find any network pane')
sys.exit(0)
else: # We're creating this tool from the TAB menu inside a network editor
pane_node = pane.pwd()
if kwargs.has_key(“outputnodename”) and kwargs.has_key(“inputindex”):
outputitem = pane_node.item(kwargs)
inputindex = kwargs
h_extra_args += ‘set arg4 = "’ + kwargs + ‘“\n’
h_extra_args += ‘set arg5 = ”’ + str(inputindex) + ‘“\n’
num_args = 6
if kwargs.has_key(”inputnodename“) and kwargs.has_key(”outputindex"):
inputitem = pane_node.item(kwargs)
outputindex = kwargs
h_extra_args += ‘set arg6 = "’ + kwargs + ‘“\n’
h_extra_args += ‘set arg9 = ”’ + str(outputindex) + ‘“\n’
num_args = 9
if kwargs.has_key(”autoplace"):
autoplace = kwargs
else:
autoplace = False
# If shift-clicked we want to auto append to the current
# node
if kwargs.has_key(“shiftclick”) and kwargs:
if inputitem is None:
inputitem = pane.currentNode()
outputindex = 0
if kwargs.has_key(“nodepositionx”) and kwargs.has_key(“nodepositiony”):
try:
pos = [ float( kwargs ),
float( kwargs )]
except:
pos = None
else:
pos = None
if not autoplace and not pane.listMode():
if pos is not None:
pass
elif outputitem is None:
pos = pane.selectPosition(inputitem, outputindex, None, -1)
else:
outputitem, inputindex)
if pos is not None:
if kwargs.has_key(“node_bbox”):
size = kwargs
pos -= size / 2
pos -= size / 2
else:
pos -= 0.573625
pos -= 0.220625
h_extra_args += ‘set arg2 = "’ + str(pos) + ‘“\n’
h_extra_args += ‘set arg3 = ”’ + str(pos) + ‘“\n’
h_extra_args += ‘set argc = ”’ + str(num_args) + ‘“\n’
child_type = pane_node.childTypeCategory().nodeTypes()
if not child_type.has_key('color'):
‘Cannot create node: incompatible pane network type’)
sys.exit(0)
# First clear the node selection
pane_node.setSelected(False, True)
h_path = pane_node.path()
h_preamble = ‘set arg1 = ”’ + h_path + ‘“\n’
h_cmd = r'''
if ($argc < 2 || ”$arg2“ == ”“) then
set arg2 = 0
endif
if ($argc < 3 || ”$arg3“ == ”“) then
set arg3 = 0
endif
# Automatically generated script
# $arg1 - the path to add this node
# $arg2 - x position of the tile
# $arg3 - y position of the tile
# $arg4 - input node to wire to
# $arg5 - which input to wire to
# $arg6 - output node to wire to
# $arg7 - the type of this node
# $arg8 - the node is an indirect input
# $arg9 - index of output from $arg6
\set noalias = 1
set saved_path = `execute(”oppwf“)`
opcf $arg1
# Node $_obj_geo1_color1 (Sop/color)
set _obj_geo1_color1 = `run(”opadd -e -n -v color color1“)`
oplocate -x `$arg2 + 0` -y `$arg3 + 0` $_obj_geo1_color1
opparm $_obj_geo1_color1 ramp ( 2 )
opparm $_obj_geo1_color1 color ( 1 0 0 ) ramp2pos ( 1 ) ramp2c ( 1 1 1 )
opset -d off -r off -h off -f off -y off -t off -l off -s off -u off -F on -c on -e on -b off $_obj_geo1_color1
opexprlanguage -s hscript $_obj_geo1_color1
opuserdata -n ‘___Version___’ -v ‘' $_obj_geo1_color1
opuserdata -n ’___toolcount___' -v ‘2’ $_obj_geo1_color1
opuserdata -n ‘___toolid___’ -v ‘sop_color’ $_obj_geo1_color1
opset -p on $_obj_geo1_color1
opcf $arg1
set oidx = 0
if ($argc >= 9 && ”$arg9“ != ”“) then
set oidx = $arg9
endif
if ($argc >= 5 && ”$arg4“ != ”“) then
set output = $_obj_geo1_color1
opwire -n $output -$arg5 $arg4
endif
if ($argc >= 6 && ”$arg6“ != ”") then
set input = $_obj_geo1_color1
if ($arg8) then
opwire -n -i $arg6 -0 $input
else
opwire -n -o $oidx $arg6 -0 $input
endif
endif
opcf $saved_path
hou.hscript(h_preamble + h_extra_args + h_cmd)
import sys
import toolutils
outputitem = None
inputindex = -1
inputitem = None
outputindex = -1
num_args = 1
h_extra_args = ‘'
if pane is None:
sys.exit(0)
inputindex = kwargs
num_args = 6
num_args = 9
autoplace = kwargs
else:
autoplace = False
# node
outputindex = 0
try:
float( kwargs )]
except:
pos = None
else:
pos = None
if pos is not None:
pass
else:
if pos is not None:
size = kwargs
pos -= size / 2
pos -= size / 2
else:
pos -= 0.573625
pos -= 0.220625
sys.exit(0)
h_cmd = r'''
set arg2 = 0
endif
set arg3 = 0
endif
\set noalias = 1
opcf $arg1
opcf $arg1
set oidx = 0
set oidx = $arg9
endif
endif
if ($arg8) then
else
endif
endif
opcf $saved_path
- goldfarb
- 3455 posts
- stu
- 246 posts
Custom from scratch I'd expect to have to handle it myself. But a simple drag-in from the network (which is what I'm doing), I'd expect to work:
1. Select thing upon which I want to perform a function.
2. Do this (dragged-from-network shelf tool functionality) to it.
Otherwise, the “drag to shelf” functionality as a high-level workflow is limited in it's usefulness if I have to backwards-engineer basic functionality after the fact.
- goldfarb
- 3455 posts
when I have 3 nodes (two color SOPs wired into a merge)
and I drag them to the shelf I get the boilerplate code
if I want to append them to an existing node I can
RMB+click on the output of the node and in the TAB menu click on the new tool
the nodes get placed and one of the color SOPs is wired to the existing node…
is this what you're trying to do?
or is there something different about your setup?
- stu
- 246 posts
