Can you help me to get the result of the shotgun find output. I can see anything in work_item.data.allDataMap or parent_item.data.allDataMap.
Thank you
Shotgun find Output
3889 7 2- Clément HECTOR
- 5 posts
- guilhermecasagrandi
- 260 posts
- Clément HECTOR
- 5 posts
- 260 posts
- Clément HECTOR
- 5 posts
- 260 posts
Yes, inside houdini´s python shell I can. I´ve shotgun running and SG python tab open inside houdini. But I still get error´s saying that Houdini can´t find SG API. As I posted, I pointed out the “PYTHONPATH” environment to the “shotgun_api3” folder. Is that correct? Do I need to add extra folders to the environment?
Got it. Was a problem with the pythonpath. Thanks for the help, and I hope someone can help you too!
Edited by guilhermecasagrandi - March 26, 2019 11:02:24
- BrookeA
- 387 posts
Clément HECTOR
Thank you
The reason that you can't find the output in the data map is that the Shotgun node is attaching the output as result data, which is a separate entity from the attribute data.
If you want to extract the information in the Python Script node and attach the information as attributes, you could do something like this:
entity_types = pdg.resultData(parent_item, "shotgun/find_entity_type", as_list=True)
entity_dicts = pdg.resultData(parent_item, "shotgun/find_entity_dict", as_list=True)
entity_ids = pdg.resultData(parent_item, "shotgun/find_entity_id", as_list=True)
for x in xrange(0, len(entity_ids)):
work_item.data.setInt("entity_ids", int(entity_ids[x]), x)
work_item.data.setString("entity_types", entity_types[x], x)
work_item.data.setString("entity_dicts", entity_dicts[x], x)
This will grab 3 distinct lists of result data from the upstream work item, where each list corresponds to a tag. It then iterates over the number of returned entities, and adds the information as attributes.
- Clément HECTOR
- 5 posts
