Run bash command in terminal using PDG
3279 4 1- Tyler Britton2
- 83 posts
- tpetrick
- 585 posts
The Generic Generator node lets you run any executable that's on your PATH as a work item. If you want to actually use the shell itself, e.g. for piping between several executables, you'll need to run it with /bin/sh (or your shell of choice). For example, setting a Generic Generator's command field to /bin/sh -c “ls -la | grep *.txt”.
In you case though, you probably just want something like deadlineslave -nogui -name “somename”, which would work fine as long as the deadlineslave executable can be found on the PATH.
- Tyler Britton2
- 83 posts
- chrisgreb
- 603 posts
- Tyler Britton2
- 83 posts
