Using Hqueue, 17.0.229, I have a bunch of PDG tasks on Hqueue and one of them failed in Hqueue, likely due to a crappy old machine running out of RAM
So I just rescheduled it after disabling the old machine, and the frame finished fine.
Sadly, PDG staunchly reports that frame as Failed and won't carry on.
What to do?
Peter B
Q: telling PDG "failed" is actually "OK"
4917 11 4- pbowmar
- 7025 posts
- chrisgreb
- 603 posts
- pbowmar
- 7025 posts
- chrisgreb
- 603 posts
- jason_iversen
- 12457 posts
That would point back to the beta-era request to have TOPs able to continually attempt to solve network, perhaps? ie. this seems like a Re-Run Until Done variation on some kind of Re-Run Continually behaviour.
Edited by jason_iversen - April 22, 2019 15:35:12
- Andrew Graham
- 150 posts
This ability would be useful. So far I have been using pdg in interactive sessions, so failed frames are fine in that scenario if you just resubmit something that is fast to execute. But anything that takes a long time or that submits pdg on a remote system will need some number of retries of tasks before bailing out anything being affected or downstream. we also wouldn't want to exit simulations for example if a task that is a sibling hits the max failure limit, so stopping the whole graph would be undesirable.
https://openfirehawk.com/ [openfirehawk.com]
Support Open Firehawk - An open source cloud rendering project for Houdini on Patreon.
This project's goal is to provide an open source framework for cloud computing for heavy FX based workflows and allows end users to pay the lowest possible price for cloud resources.
- chrisgreb
- 603 posts
Andrew Graham
FYI Local Scheduler now has ‘Exit code handling’ which can be used to retry, and Hqueue Scheduler has a ‘retries’ job parameter that can be set.
- Andrew Graham
- 150 posts
That's good to know. So with hqueue - would it bail out on a sim if other tasks downstream are failing or would that sim be safe to finish? It would be great to see this in Deadline too if it isn't already there.
- chrisgreb
- 603 posts
- Marco_M
- 5 posts
chrisgreb
You can set your ‘Cache Mode’ parm to ‘Read’ or ‘Automatic’ and re-cook your node. It should pick up the expected output and all your items as cooked right away.
What if we are using ROP Alembic? Like when we have a heavy mesh been exported in a single file, where some frames are failing?
A workaround would be to export an alembic sequence… But I've no sure if there is a way to merge them together later or if we have to create another task just for this.
- chrisgreb
- 603 posts
- mestela
- 1737 posts
