The problem is “print” node in Mat could not return the value(the console will not pop up).
Here I have 2 file which have exactly the same nodes.
The file A is from the Internet where other people have “print” node and it works well. I delete all his nodes and create some other nodes to make things easier to understand.
The “print” node could return the right value in console while rendering.
So I create a file B and do exactly the same thing. But the console just won't pop up when I start render.
By the way, the console will not pop up either if I use non-commercial houdini to open file A.
I really have no idea about why that happens.
Thanks for any clue.
Print node in Mat not working well
1010 2 1- fengshuochange
- 16 posts
- mrCatfish
- 731 posts
Not sure how you are doing it, but here's how I do it. Because I always forget, we have put this on our internal wiki here at Lost boys. I am quoting from the wiki:
- Wire the output you want to print into a print VOP.
- Wire the same output into a null and into the second output of the null, wire the print.
- In the print vop, put in “%” and check “output text to console” - this will print the text to the shell you launched Houdini from
NOTE: It looks like there is a bug in the print VOP, where it won't print a vector. If you want to print a vector, pipe it into a vector to float and then pipe this into the print VOP. - TIP: Draw a render region in your render view to speed interaction. This is also useful if you are wondering what the exact value of something is at a very specific location in your image. (EX: is a geo attribute coming through to my shader?)
Sean Lewkiw
CG Supervisor
Machine FX - Cinesite MTL
CG Supervisor
- fengshuochange
- 16 posts
Thx mrCatfish
I did link the print to a null node and check the “output text to console”.
But it still doesn't work.
And in another topic I posted(it's my first time posting topic…so I posted the same topic twice…), someone told me the file that doesn't work for me works fine with him…
So…I don't know…
So…I don't know…
Edited by fengshuochange - May 12, 2019 21:37:35
