Switching Scheduler not working without restarting Houdini
   1698   4   2
Hey
So if we switch scheduler on a node and cook again, it picks up what that last scheduler was, the only way to switch the scheduler now is to restart houdini, that sounds like a bug to me?
Using Houdini 17.5.265
Jens Martensson
Effects Supervisor @ Weta FX
Sounds like a bug, but I can't repro that problem in 17.5.292. Which node are you using ? I assume you're setting the topscheduler parm ?
Hey
Yes I am setting the scheduler on the topnet node, tried to change that, still need to restart houdini
Will try latest build
Jens Martensson
I also saw this, if I had two deadline scheduler nodes, different settings on each, if I changed which scheduler was being used on any given fetch, it didn't pick up the change.
it seemed I could only have one instance of the scheduler node.
https://openfirehawk.com/ [openfirehawk.com]
Support Open Firehawk - An open source cloud rendering project for Houdini on Patreon.
This project's goal is to provide an open source framework for cloud computing for heavy FX based workflows and allows end users to pay the lowest possible price for cloud resources.
I must be missing something simple because I really can't reproduce the problem. Is it possible to post the steps or a hip ?
