Hey Vux
latest build doesn't seem to install if i don't use the houdini.env.
I'm using bash to set my environment and HOUDINI_PATH - rather then setting in houdini.env - and i get this error
File “modeler_menu”, line 1, in <module>
File “/mnt/FRAMESTORE/common/dev/pipeline/houdini/DM/python2.7libs/dm/modeling_tools.py”, line 2, in <module>
import ui, geo_utils
File “/mnt/FRAMESTORE/common/dev/pipeline/houdini/DM/python2.7libs/dm/ui.py”, line 21, in <module>
from modeler_hotkeys import hotkeys
ImportError: No module named modeler_hotkeys
is this fixable?
It works fine setting HOUDINI_PATH in the env file - but i'd prefer to use bash and a .sh script -
Can you see what might be the problem?
N
DM 1.5 for Houdini 17.5 release
10968 23 1- Neil78
- 268 posts
- Alexey Vanzhula
- 538 posts
Neil78
Hey Vux
is this fixable?
N
Your environment should have DM variable which points to the DM folder. Without it DM will not work
- Neil78
- 268 posts
- Alexey Vanzhula
- 538 posts
Set Flow SOP preview:
1. https://vimeo.com/347248950 [vimeo.com]
2. https://vimeo.com/347476024 [vimeo.com]
