I was wondering how to fix HighField Draw Mask functionality on HighField that projects custom geometry (cliff wall). The overall purpose is t do set dressing on a cliff.
The Highfield Draw Mask seems not to work on a HighField if it's being positioned vertically. So the way I found to quickly fix it (with knowledge of expressions and scripting) was to edited the draw mask node content. In Attribute Wrangle named “project” I changes Run Over from points to Detail(only once) and it made it work.
However, now when I use the draw mask with this alteration on HighField Projection it seems to appear only on the area where projection has no affect. The curve of draw mask is there but no mask.
I suppose the issue is somewhere down in next node volumewrangle inside the drawmask content?
Any tips highly appreciated,
Inga.
Vertical Highfield Projection and Highfield Draw Mask
535 0 1- inga
