I am struggling to use the rop Fetch node with our in-house sop/rop node. We have a convenience node which wraps the rop alembic and rop alembic node into a single hda and generates local or server filepaths. I have build a simplified hda and attached a setup scene.
My Problem is as follow: The Rop Fetch starts cooking the first item and after a few seconds stops. The workitem does not finish but also does not error. The in-house rop cooks correctly and caches are generated on disc. If I dirty the node and recook it again all workitems are marked as done.
Did anyone run into similar problems or may have a solution ?
Dome
Rop Fetch with custom Rop Hda does not cook propperly
2787 4 2- DominikPott
- 15 posts
- tpetrick
- 585 posts
When cooking ROPs as a batch, PDG needs to be able to set the pre/post frame callback on the target ROP. These are used by PDG in order to alert the graph that a batch sub item has begun/completed cooking. If you promote the script parameters from your custom ROP asset onto the top level HDA itself, they should be picked up automatically.
- DominikPott
- 15 posts
Thank you so much for the help . It works now with one minor problem. When I do not cook the ropfetch as one batch only the fist bucket cooks. The other buckets work endlessly on their first workitem. I also get a long list of warnings similar to the following on the ropfetch:
and also my local scheduler errors:
If added a new attachment which should reproduce the problem.
Cheers and many thanks
Dome
Warning
PDG cook warning: Notification for item ropfetch0195_1 with subindex -1 that is no longer active in the scheduler
Error
PDG Error: Could not find batch workitem 'ropfetch0120_1' with subindex 17
Dome
Edited by DominikPott - Oct. 8, 2019 17:12:05
- tpetrick
- 585 posts
This looks like a bug on our end. The ROP Fetch isn't properly handling your node since it's actually a SOP, not a ROP. It ends up cooking the full frame range even though the ROP Fetch is configured to cook partial frame ranges in separate batches. I'll have a fix in tomorrow's daily build that addresses the issue
- DominikPott
- 15 posts
